1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Teledyne RETIGA E7
From: John Dobbins via Tech-talk <[email protected]>
To: "Wlodek, Jakub" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 15 Apr 2025 13:55:32 +0000
Thanks Jakub. This is very helpful.  John
Sent: Tuesday, April 15, 2025 9:53 AM
To: [email protected] <[email protected]>; John Dobbins <[email protected]>
Hi John,
I'm the author of the ADKinetix driver. I had a look at the E7 datasheet on the Teledyne website, and I think that both drivers should work with it, since it is just using the PVCam SDK as you mentioned, although I don't have a unit to test this with. We've used the ADKinetix driver with our Kinetix cameras using the USB 3.1 connection mode without issue, and the E7 appears to use USB as well.
I'd recommend trying to go with the ADKinetix driver if possible - it uses the newer event-based API (rather than the older polling one) for image callbacks, which allows for much higher framerates. When we originally set up our Kinetix cameras with ADPvCam we would only get an inconsistent ~30 Hz or so in the default pixel mode. Once we wrote the driver with the newer API and switched to that we were able to hit the advertised 90 Hz at full resolution without an issue.
I think the version of PVCam that I include with ADKinetix is a bit older than the one you are getting, and I am not sure if support for the E7 is only included with the newer version - so you may just need to replace the libraries in the kinetixSupport directory.
If you run into any issues feel free to shoot me an email or make an issue on the github repo.
Jakub Wlodek
Technology Engineer
Data Acquisition and Detectors
National Synchrotron Light Source II
Office: 631.344.7599
[email protected]
Twitter | Facebook | Instagram | LinkedIn
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Tuesday, April 15, 2025 9:37 AM
Subject: Teledyne RETIGA E7
All,
We are getting a Teledyne RETIGA E7.  This has  PVCAM Linux 3.10.0.3
I see areaDetector/ADPvCam
And  areaDetector/ADKinetix  "for communicating with Teledyne Photometrics cameras that use the PvCam SDK, with special focus put on the high speed Kinetix product line"
Does anyone know if either of these with work with the E7?
As always, thanks.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Teledyne RETIGA E7 John Dobbins via Tech-talk
Re: Teledyne RETIGA E7 Wlodek, Jakub via Tech-talk
Prev: Re: Teledyne RETIGA E7 Wlodek, Jakub via Tech-talk
Next: Re: Link error in MRF event system due to reference clock glitch Hong, Ran via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Problem building sequencer Dudley, David via Tech-talk
