1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: cross-compiling tirpc header
From: Pierrick M Hanlet via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 18 Apr 2025 17:31:42 +0000
Greetings all,
I've recently added the raspberrypi5 platform to my list of supported
platforms and in attempting to build asyn
found that I've never correctly pointed my builds to pick up the correct
header file for tirpc:
/usr/local/products/buildroot/raspberrypi5_generic/host/usr/bin/aarch64-linux-gcc
-D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET -DUSE_TYPED_DSET
-DUSE_TYPED_DRVET -DBUILDING_asyn_API   -DUNIX -Dlinux      -O3 -g
-Wall -Werror-implicit-function-declaration -DUSE_TYPED_RSET
-DUSE_TYPED_DSET -DUSE_TYPED_DRVET -DHAVE_LSREC -DHAVE_CALCMOD
-DHAVE_DEVINT64       -D_FILE_OFFSET_BITS=64 -g -fPIC -I. -I../O.Common
-I. -I. -I../../asyn/drvAsynSerial/os/Linux
-I../../asyn/drvAsynSerial/os/default -I.. -I../../asyn/asynDriver
-I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces
-I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions
-I../../asyn/asynPortDriver -I../../asyn/asynPortClient
-I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11
-I../../asyn/drvPrologixGPIB -I../../asyn/gsIP488 -I../../asyn/ni1014
-I../../asyn/devGpib -I../../include/compiler/gcc
-I../../include/os/Linux -I../../include
-I/usr/local/epics/securePVA/Support/ipac/include
-I/usr/local/epics/securePVA/Support/seq/include
-I/usr/local/epics/securePVA/Support/calc/include
-I/usr/local/epics/securePVA/Support/sscan/include
-I/usr/local/epics/securePVA/base/include/compiler/gcc
-I/usr/local/epics/securePVA/base/include/os/Linux
-I/usr/local/epics/securePVA/base/include -I/usr/include/tirpc
-I/usr/local/products/buildroot/raspberrypi5_generic/host/usr/aarch64-buildroot-linux-gnu/sysroot/usr/include
-I/usr/local/products/buildroot/raspberrypi5_generic/host/usr/aarch64-buildroot-linux-gnu/sysroot/usr/include/tirpc
-MM -MF asynManager.d  ../../asyn/asynDriver/asynManager.c
aarch64-linux-gcc: ERROR: unsafe header/library path used in
cross-compilation: '-I/usr/include/tirpc'
In configure/os/CONFIG_SITE.Common.linux-arm_raspberrypi5, I have:
OP_SYS_INCLUDES+=-I$(GNU_DIR)/$(ARCH_DIR)/sysroot/usr/include
OP_SYS_INCLUDES+=-I$(GNU_DIR)/$(ARCH_DIR)/sysroot/usr/include/tirpc
OP_SYS_LDLIBS += -ltirpc
Should I be using a different environment variable?
I'm using base-7.0.9 with C++20 on AL9 and asyn-R4-44
Many thanks,
Pierrick
Pierrick Hanlet
Fermi National Accelerator
Accelerator Front End Controls
+1-630-840-5555 -- lab
+1-312-687-4980 -- mobile
"Whether you think you can or think you can't, you're right" -- Henry Ford
Re: cross-compiling tirpc header Pierrick M Hanlet via Tech-talk
Prev: CaLab - strange replies Dariush Hampai via Tech-talk
Next: Re: cross-compiling tirpc header Pierrick M Hanlet via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
ANJ, 18 Apr 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
