1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: EPICS VAL/DVAL garbage value
To: [email protected]
Date: Thu, 24 Apr 2025 14:19:27 +0900
And this is my github!
https://github.com/whitetiger112233/tech
2025년 4월 24일 (목) 오후 2:05, 백호령 <[email protected]>님이 작성:
Hello, we are currently working on developing a new controller.
We are developing a controller with an integrated controller+driver for simple motor control.
Raspberry Pi, Panasonic PLC, and Autonics' MD5-HD14 drives were connected, and EPICS 3.15.6 and Synaps were installed to create a motor control module.
One problem is that we have to set offset values because DVAL, VAL values are executed with strange non-zero values.
ex)
State: Connected Running
Value: VInt[-939441500, 202
Value: VInt[424962560, 2025/04/24 13:51:26.222]
The motor runs well, but I'd like to ask for advice because it's inconvenient to use it this way.
I'm attaching the results of the st.cmd file execution as well. (I don't think there's anything wrong with executing it.)
 ./st.cmd
#!../../bin/linux-arm/Tech
cd "/usr/local/epics/iocs/Tech/iocBoot/iocTech"
< envPaths
epicsEnvSet("IOC","iocTech")
epicsEnvSet("TOP","/usr/local/epics/iocs/Tech")
epicsEnvSet("MODULES","/usr/local/epics/modules")
epicsEnvSet("MOTOR","/usr/local/epics/modules/motor")
epicsEnvSet("ASYN","/usr/local/epics/modules/asyn")
epicsEnvSet("CALC","/usr/local/epics/modules/calc")
epicsEnvSet("AUTOSAVE","/usr/local/epics/modules/autosave")
epicsEnvSet("SNCSEQ","/usr/local/epics/modules/seq")
epicsEnvSet("SSCAN","/usr/local/epics/modules/sscan")
epicsEnvSet("IPAC","/usr/local/epics/modules/ipac")
epicsEnvSet("BUSY","/usr/local/epics/modules/busy")
epicsEnvSet("EPICS_BASE","/usr/local/epics/base")
< pvSettings
epicsEnvSet("P","IOC:")
epicsEnvSet("M1","m1")
epicsEnvSet("M2","m2")
epicsEnvSet("M3","m3")
epicsEnvSet("M4","m4")
epicsEnvSet("M5","m5")
epicsEnvSet("M6","m6")
epicsEnvSet("M7","m7")
epicsEnvSet("M8","m8")
cd "/usr/local/epics/iocs/Tech"
dbLoadDatabase("dbd/Tech.dbd")
Tech_registerRecordDeviceDriver(pdbbase)
## Serial Configuration
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyAMA0",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","19200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","odd")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
asynOctetSetInputEos("SERIALPORT",0,"\r")
asynOctetSetOutputEos("SERIALPORT",0,"\r")
#asynSetTraceIOMask("SERIALPORT", 0, 2)
#asynSetTraceMask("SERIALPORT", 0, 255)
TechSetup(1,8,10)
TechConfig(0,"SERIALPORT")
## Load record instances
dbLoadRecords "db/motor_record.db","P=IOC:,M=m1,S=0"
dbLoadRecords "db/motor_record.db","P=IOC:,M=m2,S=1"
dbLoadRecords "db/motor_record.db","P=IOC:,M=m3,S=2"
dbLoadRecords "db/motor_record.db","P=IOC:,M=m4,S=3"
dbLoadRecords "db/motor_record.db","P=IOC:,M=m5,S=4"
dbLoadRecords "db/motor_record.db","P=IOC:,M=m6,S=5"
dbLoadRecords "db/motor_record.db","P=IOC:,M=m7,S=6"
dbLoadRecords "db/motor_record.db","P=IOC:,M=m8,S=7"
#dbLoadRecords "db/motorUtil.db","P=$(P)"
## Begin: Setup autosave/restore
# If all PVs don't connect continue anyway
save_restoreSet_IncompleteSetsOk(1)
# created save/restore backup files with date string
# useful for recovery.
save_restoreSet_DatedBackupFiles(0)
# Where to find the list of PVs to save
set_requestfile_path("./")
# Where to write the save files that will be used to restore
set_savefile_path("./", "autosave")
# Prefix that is use to update save/restore status database
# records
#save_restoreSet_status_prefix("$(LOCA):$(DEV):")
#save_restoreSet_status_prefix("$(P)")
## Restore datasets
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
# End: Setup autosave/restore
## Set this to see messages from mySub
#var mySubDebug 1
## Run this to trace the stages of iocInit
#traceIocInit
iocInit
Starting iocInit
## EPICS R3.15.6
## EPICS Base built Dec 3 2018
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
#motorUtilInit("$(P)")
create_monitor_set("auto_settings.req", 30, "P=IOC:,M1=m1,M2=m2,M3=m3,M4=m4,M5=m5,M6=m6,M7=m7,M8=m8")
## Start any sequence programs
#seq sncTech,"user=root"
epics> auto_settings.sav: 304 of 304 PV's connected
epics>
epics> dbl
IOC:m1_able
IOC:m2_able
IOC:m3_able
IOC:m4_able
IOC:m5_able
IOC:m6_able
IOC:m7_able
IOC:m8_able
IOC:m1_ableput
IOC:m2_ableput
IOC:m3_ableput
IOC:m4_ableput
IOC:m5_ableput
IOC:m6_ableput
IOC:m7_ableput
IOC:m8_ableput
IOC:m1
IOC:m2
IOC:m3
IOC:m4
IOC:m5
IOC:m6
IOC:m7
IOC:m8
IOC:m1_vCh
IOC:m1_twCh
IOC:m2_vCh
IOC:m2_twCh
IOC:m3_vCh
IOC:m3_twCh
IOC:m4_vCh
IOC:m4_twCh
IOC:m5_vCh
IOC:m5_twCh
IOC:m6_vCh
IOC:m6_twCh
IOC:m7_vCh
IOC:m7_twCh
IOC:m8_vCh
IOC:m8_twCh
Can you guys give me some advice please?
Always Appreciate your helps and advices.
Best and Regards.
Baeg
Re: EPICS VAL/DVAL garbage value Mark Rivers via Tech-talk
EPICS VAL/DVAL garbage value 백호령 via Tech-talk
Prev: EPICS VAL/DVAL garbage value 백호령 via Tech-talk
Next: Re: EPICS VAL/DVAL garbage value Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
