1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Problems setting up MCA BrukerQM100
From: "Lott, Eva via Tech-talk" <[email protected]>
To: Jörn Dreyer <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 28 Apr 2025 11:58:16 +0000
Apologies for the lack of errors - it was correctly compiling and not giving error output, beyond `drvAsynIPPortConfigure` not being available as a command in the compiled IOC. Asyn is already in the list of linked libraries.
I've added it seperately, with
DBD += $(SUPPORT)/asyn/dbd/drvAsynIPPort.dbd
here
which did the trick.
Sent: 28 April 2025 13:15
To: [email protected]
Cc: Lott, Eva
Hi Eva,
as you did not post any error messages you get when compiling the ioc, I can only guess whet went wrong.
It is not enought to just add drvAsynIPPort.dbd to the DBDS in the Makefile. You also have to add asyn to the list of linked libraries.
Jörn
Am Montag, 28. April 2025, 11:14:13 Mitteleuropäische Sommerzeit schrieb Lott, Eva via Tech-talk:
> Hi,
> I've been trying to set up an MCA ioc for the Bruker XFlash. I've built `mcaBrukerQM100.exe` (linking the hardware control dll), and am now in the process of writing the iocBoot for it.
> My problem is that this ioc doesn't link `drvIPPortConfigure` - I need an IP port for running `BrukerQM100Config`. I've tried linking drvAsynIPPort.dbd in https://urldefense.us/v3/__https://github.com/epics-modules/mca/blob/master/mcaApp/RontecSrc/mcaBrukerQM100Include.dbd__;!!G_uCfscf7eWS!cGAGhOJw5qyshYDXwAdWTMAdGELjGjKZP4z2cQWyTP3EelgE-wwIPDmX2Fqz4mkHCEUd9A_p47g0SCbpYAVjnkSkYJwd8Oz5mw$  to no avail.
> Does anyone have any examples of a production mcaBrukerQM100 support module that I can look at?
> Eva
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
> Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> 14109 Berlin
> Deutschland
> Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen enthalten. Wenn Sie diese E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den*die Absender*in und vernichten Sie diese Mail. Das unerlaubte Kopieren, die Veröffentlichung sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
> This email may contain confidential and/or proprietary information. If you have received this e-mail in error, please inform the sender immediately and destroy this e-mail. Unauthorized copying, publishing or distribution of this e-mail is not permitted.
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
http://www.hzdr.de
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
Postadresse:
14109 Berlin
Deutschland
Problems setting up MCA BrukerQM100 Lott, Eva via Tech-talk
Re: Problems setting up MCA BrukerQM100 Jörn Dreyer via Tech-talk
Prev: Re: Problems setting up MCA BrukerQM100 Jörn Dreyer via Tech-talk
Next: Re: Problems setting up MCA BrukerQM100 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
