Your gcc seems to be targetting x86_64-pc-msys whereas mine targets x86_64-w64-mingw32 I think that may be the
problem. For gcc -v I see
$ gcc -v
Using built-in specs.
COLLECT_GCC=C:\msys64\mingw64\bin\gcc.exe
COLLECT_LTO_WRAPPER=C:/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/14.2.0/lto-wrapper.exe
Target: x86_64-w64-mingw32
Configured with: ../gcc-14.2.0/configure --prefix=/mingw64 --with-local-prefix=/mingw64/local --buil
d=x86_64-w64-mingw32 --host=x86_64-w64-mingw32 --target=x86_64-w64-mingw32 --with-native-system-head
er-dir=/mingw64/include --libexecdir=/mingw64/lib --enable-bootstrap --enable-checking=release --wit
h-arch=nocona --with-tune=generic --enable-mingw-wildcard --enable-languages=c,lto,c++,fortran,ada,o
bjc,obj-c++,rust,jit --enable-shared --enable-static --enable-libatomic --enable-threads=posix --ena
ble-graphite --enable-fully-dynamic-string --enable-libstdcxx-filesystem-ts --enable-libstdcxx-time
--disable-libstdcxx-pch --enable-lto --enable-libgomp --disable-libssp --disable-multilib --disable-
rpath --disable-win32-registry --disable-nls --disable-werror --disable-symvers --with-libiconv --wi
th-system-zlib --with-gmp=/mingw64 --with-mpfr=/mingw64 --with-mpc=/mingw64 --with-isl=/mingw64 --wi
th-pkgversion='Rev3, Built by MSYS2 project' --with-bugurl=https://github.com/msys2/MINGW-packages/i
ssues --with-gnu-as --with-gnu-ld --disable-libstdcxx-debug --enable-plugin --with-boot-ldflags=-sta
tic-libstdc++ --with-stage1-ldflags=-static-libstdc++
Thread model: posix
Supported LTO compression algorithms: zlib zstd
gcc version 14.2.0 (Rev3, Built by MSYS2 project)
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/x86_64-pc-msys/13.3.0/lto-wrapper.exe
Target: x86_64-pc-msys
Configured with: /c/S/B/src/gcc-13.3.0/configure --build=x86_64-pc-msys --prefix=/usr --libexecdir=/usr/lib --enable-bootstrap --enable-static --enable-shared --enable-shared-libgcc --enable-version-specific-runtime-libs
--with-arch=nocona --with-tune=generic --disable-multilib --enable-__cxa_atexit --with-dwarf2 --enable-languages=c,c++,lto --enable-graphite --enable-threads=posix --enable-libatomic --enable-libgomp --disable-libitm --enable-libquadmath --enable-libquadmath-support
--disable-libssp --disable-win32-registry --disable-symvers --with-gnu-ld --with-gnu-as --disable-isl-version-check --enable-checking=release --without-libiconv-prefix --without-libintl-prefix --with-system-zlib --enable-linker-build-id --enable-libstdcxx-filesystem-ts
Thread model: posix
gcc version 13.3.0 (GCC)
The windows-x64 target is only for a visual studio windows build, windows-x64-mingw is correct for MinGW. Can you just check that you ran this build from a “MSYS2 MinGW 64bit” window rather than
a “MSYS2 MSYS” terminal. What does
gcc -v
Show?
Freddie
On Behalf Of Wang, Andrew via Tech-talk
Sent: 28 April 2025 17:38
To: EPICS tech-talk <[email protected]>
Subject: FYI, the msys2 compilation approach is not working
Hi all,
I’m following the instructions on this
webpage for installing EPICS using msys2.
Everything worked fine up until the “Download and build EPICS Base” section. After running “export EPICS_HOST_ARCH=windows-x64-mingw”, I get the following errors. Do you suggest that I potentially
change the architecture to windows-x64, rather than windows-x64-mingw?
../osi/os/WIN32/epicsTempFile.c: In function ‘epicsTempFile’:
../osi/os/WIN32/epicsTempFile.c:31:20: warning: implicit declaration of function ‘_tempnam’; did you mean ‘tempnam’? [-Wimplicit-function-declaration]
31 | char * pName = _tempnam("c:\\tmp", "epics");
| tempnam
../osi/os/WIN32/epicsTempFile.c:31:20: warning: initialization of ‘char *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
../osi/os/WIN32/epicsTempFile.c:45:24: error: ‘_O_CREAT’ undeclared (first use in this function); did you mean ‘O_CREAT’?
45 | int openFlag = _O_CREAT | _O_EXCL | _O_RDWR |
| O_CREAT
../osi/os/WIN32/epicsTempFile.c:45:24: note: each undeclared identifier is reported only once for each function it appears in
../osi/os/WIN32/epicsTempFile.c:45:35: error: ‘_O_EXCL’ undeclared (first use in this function); did you mean ‘O_EXCL’?
| O_EXCL
../osi/os/WIN32/epicsTempFile.c:45:45: error: ‘_O_RDWR’ undeclared (first use in this function); did you mean ‘O_RDWR’?
| O_RDWR
../osi/os/WIN32/epicsTempFile.c:46:13: error: ‘_O_SHORT_LIVED’ undeclared (first use in this function)
46 | _O_SHORT_LIVED | _O_BINARY | _O_TEMPORARY;
../osi/os/WIN32/epicsTempFile.c:46:30: error: ‘_O_BINARY’ undeclared (first use in this function); did you mean ‘O_BINARY’?
| O_BINARY
../osi/os/WIN32/epicsTempFile.c:46:42: error: ‘_O_TEMPORARY’ undeclared (first use in this function)
../osi/os/WIN32/epicsTempFile.c:47:40: error: ‘_S_IWRITE’ undeclared (first use in this function); did you mean ‘S_IWRITE’?
47 | int fd = open(pName, openFlag, _S_IWRITE);
| S_IWRITE
../osi/os/WIN32/epicsTempFile.c:50:24: warning: implicit declaration of function ‘_fdopen’; did you mean ‘fdopen’? [-Wimplicit-function-declaration]
50 | pNewFile = _fdopen(fd, "w+b");
| fdopen
../osi/os/WIN32/epicsTempFile.c:50:22: warning: assignment to ‘FILE *’ from ‘int’ makes pointer from integer without a cast [-Wint-conversion]
gcc -D_MINGW -D__USE_MINGW_ANSI_STDIO -O3 -Wall -m64 -DEPICS_BUILD_DLL -DEPICS_CALL_DLL -I. -I../O.Common -I. -I../osi/compiler/gcc -I../osi/compiler/default -I. -I../osi/os/WIN32
-I../osi/os/default -I.. -I../as -I../bucketLib -I../calc -I../cvtFast -I../cppStd -I../cxxTemplates -I../dbmf -I../ellLib -I../env -I../error -I../fdmgr -I../flex -I../freeList -I../gpHash -I../iocsh -I../log -I../macLib -I../misc -I../osi -I../pool -I../ring
-I../taskwd -I../timer -I../yacc -I../yacc -I../yajl -I../../../../include/compiler/gcc -I../../../../include/os/WIN32 -I../../../../include -o ccl.obj -c ../flex/ccl.c
In file included from ../flex/flexdef.h:38,
from ../flex/ccl.c:29:
../osi/os/WIN32/osiUnistd.h:16:10: fatal error: direct.h: No such file or directory
16 | #include <direct.h>
compilation terminated.
make[4]: *** No rule to make target 'ccl.obj', needed by 'e_flex.exe'. Stop.
make[4]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom/src/O.windows-x64-mingw'
make[3]: *** [../../../configure/RULES_ARCHS:58: install.windows-x64-mingw] Error 2
make[3]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom/src'
make[2]: *** [../../configure/RULES_DIRS:85: src.install] Error 2
make[2]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:85: libcom.install] Error 2
make[1]: Leaving directory '/c/Users/wang126/base-R7.0.4.1/modules'
make: *** [configure/RULES_DIRS:85: modules.install] Error 2
Purple
ribbon awareness
