1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Unable to mind .lib files after successfully compiling EPICS using mingw64
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Tue, 29 Apr 2025 01:01:05 +0000
Hi all,
I have been tasked with building EPICS on Windows. I was able to get it compiling using mingw64. I basically followed the instructions here (https://docs.epics-controls.org/en/latest/getting-started/installation-windows-msys2.html), albeit I did not use the tar.gz file. I instead cloned the epics-base repository.
I have been able to run an IOC and all of that. However, now I am trying to get mca to work, which requires com.lib and ca.lib. However, I do not see these in my lib directory. I only find com.dll.a and ca.dll.a, which to my understanding is not a static library.
The examples compilations in mca all use .lib. (https://github.com/epics-extensions/matlab_ca/blob/master/alt_compile/mcacompile_win64_mscc.m)
Please advise?
Purple ribbon awareness
Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Mark Rivers via Tech-talk
Prev: Re: FYI, the msys2 compilation approach is not working Johnson, Andrew N. via Tech-talk
Next: Re: Unable to mind .lib files after successfully compiling EPICS using mingw64 Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
