1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Modbus problem bit swap Wago PLC
To: Jeffrey Gamsby <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 2 May 2025 19:28:32 +0000
Hi Jeffrey,
What do you mean by “bit-swap”?  Do you mean the values 0 and 1 are swapped, or that the order of the bits is swapped?
From: Tech-talk <[email protected]> On Behalf Of Jeffrey Gamsby via Tech-talk
Sent: Friday, May 2, 2025 5:29 AM
To: [email protected]
Subject: Modbus problem bit swap Wago PLC
Hi All,
 I am using a Wago PLC and Epics asyn-R4-43/Modbus R3-2, and I am seeing some differences in the FC2 reads depending on the Wago module that is used.
If the 750-400/500 series module DO/DI are used, the reads come back as expected, but if the 750-1400/1500 series are used there is a bit swap when reading.
Here is my current Asyn port configuration, I have tried the different data types as enums and strings but that doesn't change anything.
I can make it work, just trying to understand why I get the bit swap when using different modules on the PLC.
Here is my config:
cmd file:
# Bit read access, Function code 2
drvModbusAsynConfigure("FC2", "sim1", 0, 2,  0, 32, 0, 100, "Wago")
and the db record
# bi record template for register inputs
record(bi,"$(P)$(R)") {
    field(DTYP,"asynUInt32Digital")
    field(INP,"@asynMask($(PORT) $(OFFSET) 0x1)")
    field(SCAN,"$(SCAN)")
    field(ZNAM,"$(ZNAM)")
    field(ONAM,"$(ONAM)")
    field(ZSV,"$(ZSV)")
    field(OSV,"$(OSV)")
and my substitutions file:
# READ COILS - FUNCTION CODE 2
# Reads WAGO MB Output Bits
file "$(MODBUS)/db/bi_bit.jeff.template" { pattern
{P,        R,        PORT,    OFFSET,      ZNAM,   ONAM,  ZSV,       OSV,    SCAN}
{SIM1:,    FC2_0,     FC2,     0,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_1,     FC2,     1,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_2,     FC2,     2,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_3,     FC2,     3,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_4,     FC2,     4,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_5,     FC2,     5,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_6,     FC2,     6,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_7,     FC2,     7,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_8,     FC2,     8,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_9      FC2,     9,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_10,     FC2,     10,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_11,     FC2,     11,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_12,     FC2,     12,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_13,     FC2,     13,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_14,     FC2,     14,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
{SIM1:,    FC2_15,     FC2,     15,        Low,    High,  NO_ALARM,  MAJOR,  "1 second"}
Re: Modbus problem bit swap Wago PLC Brown, Garth via Tech-talk
Modbus problem bit swap Wago PLC Jeffrey Gamsby via Tech-talk
Prev: Re: aps epics site not accessible from Europe at the moment? Johnson, Andrew N. via Tech-talk
Next: Re: EPICS build problem Federico Galdenzi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Modbus problem bit swap Wago PLC Jeffrey Gamsby via Tech-talk
Next: Re: Modbus problem bit swap Wago PLC Brown, Garth via Tech-talk
