Hi Andrea,
The Makefile modifications are reasonably straightforward. The way I normally do this is as follows:
Have the Database specified in the "DB" macro; i.e. "DB += myDb.db" (this probably already exists in your IOC's Db/Makefile file)
Have a file named "myDb.py". This is your epicsdbbuilder script.
Add this rule to the Makefile, below that line. Note the "python" line should be indented with a tab:
After this, running "make" should work as expected and you should see "myDb.db" appear in the built top level "db" folder.
To explain the Makefile magic:
%.db expands to the name of the database file the EPICS build system is currently trying to build
../%.py will cause EPICS to target the Python file of the same name as the database file
python $< $@ will execute "python", passing "$<" (the file path to the Python script) and "$@", the full file path to the database being created. This is why you need to output the database contents to "sys.argv[1]".
Hope that helps!
Alex Wells
Dear colleagues,
At this moment, my development flow is as follows. I create the python file to build the database file inside the “Db” folder, then I manually execute it, and then I run make.
Indeed, in the default Makefile obtained from “makeBaseApp.pl -t ioc”, I see that the last lines read:
# ADD RULES AFTER THIS LINE
This means that I can, in principle, add a rule so that the python script is executed automatically. However, I am not familiar enough with EPICS compilation system (and in general with Makefile) to write this rule. May I ask you for suggestions?
Bests,
Andrea Celentano
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt
by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
- Re: EPICS app, Db Makefile, rule for python-generated Db file Johnson, Andrew N. via Tech-talk
- EPICS app, Db Makefile, rule for python-generated Db file Andrea Celentano via Tech-talk
IOC warning when connecting to 64 devices Abdalla Ahmad via Tech-talk
Re: IOC warning when connecting to 64 devices Ralph Lange via Tech-talk
<2025>
2026
<2025>
2026
