1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Checksum for StreamDevice input with regular expression
From: Zimoch Dirk via Tech-talk <[email protected]>
To: "Baker, Keith (DLSLtd,RAL,LSCI)" <[email protected]>
Date: Thu, 8 May 2025 11:33:43 +0000
Hi Keith
Yes, the regsub modifies the input buffer on which the checksum is calculated. I never thought about that case. It would make sense of course to calculate the checksum on the original input. Not quite sure how to implement that best, though. I would need to keep the original around for any potential checksum while using the modified string for anything else. That means I need to go away from in-place substitution and have to handle checksums different from all other formats.
For the time being, I see two work-arounds: 1. ignore the checksum, as you did, or 2. post-process the strings externally, for example in an sCalcout record.
Dirk
Am 08.05.2025 um 13:09 schrieb Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk <[email protected]>:
Hello.
I am trying to read in a datetime string, format YYMMDDhhmmss, but would prefer it in a more human readable format such as
YY-MM-DD hh:mm:ss
My protocol file is fine if I just read the string as YYMMDDhhmmss and the checksum passes.
Then I can insert the extra characters with a regular _expression_ to give the string I want but the checksum now fails.
I am forced to omit the checksum and just ignore extra input.
Is this the expect behaviour or might I be doing something wrong?
If so, can someone suggest a more elegant solution for the format conversion instead of a regular _expression_, perhaps with an sCalcout record?
I’m sure someone will ask for my code so here it is. I’m actually using redirection to put the date and time into two separate records, $1:DATE and $1:TIME. I’ve shown the evolution of my protocol attempts.
readTime {
    out BEL "01ZR \$CS" ETX;
# Basic input with no reformatting.
#    in BEL "01ZR","%(\$1:DATE)6s%(\$1:TIME)6s\$CS" ETX;
# Next line works but actually does nothing in the regular _expression_.
#    in BEL "01ZR","%#/([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})/\1\2\3\4\5\6/%(\$1:DATE)6s%(\$1:TIME)6s\$CS" ETX;
# Next line gives a checksum error.
#    in BEL "01ZR","%#/([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})/\1:\2:\3\4-\5-\6/%(\$1:DATE)8s%(\$1:TIME)8s\$CS" ETX;
# So this is my best solution so far but omitting the checksum.
    in BEL "01ZR","%#/([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})([0-9]{2})/\1:\2:\3\4-\5-\6/%(\$1:DATE)8s%(\$1:TIME)8s";
    ExtraInput = Ignore; #Suspect checksum calculated after regex so will not match input.
If I can get the regular _expression_ to work with a checksum, maybe someone could also suggest a more elegant regular _expression_.
Keith Baker
Diamond Light Source Ltd
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
RE: Checksum for StreamDevice input with regular expression Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Prev: Checksum for StreamDevice input with regular expression Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Next: RE: Checksum for StreamDevice input with regular expression Baker, Keith (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
