1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: fedora 42 and makeBaseApp -t example
From: Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Mon, 12 May 2025 10:58:38 +0200
A student has updated his laptop to Fedora 42.
When trying to build myExample (makeBaseApp.pl -t example myExample) he gets the following error:
Updating VCS header ../O.Common/myexampleVersion.h
   to:   myexampleVERSION = "2025-05-12T10:47+0200"
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET  -D_X86_64_ -DUNIX  -Dlinux   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/d/EPICS/epics-base/include/compiler/gcc -I/home/d/EPICS/epics-base/include/os/Linux -I/home/d/EPICS/epics-base/include        -MM -MF devmyexampleVersion.d  ../devmyexampleVersion.c
perl -CSD /home/d/EPICS/epics-base/bin/linux-x86_64/genVersionHeader.pl   -t ../../.. -N myexampleVERSION -V "" ../O.Common/myexampleVersion.h
Keeping VCS header ../O.Common/myexampleVersion.h
/usr/bin/gcc  -D_GNU_SOURCE -D_DEFAULT_SOURCE        -DUSE_TYPED_RSET  -D_X86_64_ -DUNIX  -Dlinux   -O3 -g   -Wall -Werror-implicit-function-declaration      -mtune=generic     -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/home/d/EPICS/epics-base/include/compiler/gcc -I/home/d/EPICS/epics-base/include/os/Linux -I/home/d/EPICS/epics-base/include        -c ../xxxRecord.c
../xxxRecord.c: In function ‘init_record’:
../xxxRecord.c:101:21: error: too many arguments to function ‘pdset->init_record’; expected 0, have 1
 101 |         if((status=(*pdset->init_record)(prec))) return(status);
../xxxRecord.c:74:17: note: declared here
  74 |     DEVSUPFUN   init_record; /*returns: (-1,0)=>(failure,success)*/
../xxxRecord.c: In function ‘process’:
../xxxRecord.c:121:13: error: too many arguments to function ‘pdset->read_xxx’; expected 0, have 1
 121 |     status=(*pdset->read_xxx)(prec);
../xxxRecord.c:76:17: note: declared here
  76 |     DEVSUPFUN   read_xxx;
make[1]: *** [/home/d/EPICS/epics-base/configure/RULES_BUILD:260: xxxRecord.o] Error 1
make[1]: Leaving directory '/home/d/Desktop/temp/myexampleApp/src/O.linux-x86_64'
make: *** [/home/d/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
Is that known?
Danke Heinz
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: fedora 42 and makeBaseApp -t example Ralph Lange via Tech-talk
Prev: RE: How to know which CA client(IP address) modified a PV Mercado, Ronaldo (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: fedora 42 and makeBaseApp -t example Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Prev: Re: Build Problem for IOC Federico Galdenzi via Tech-talk
ANJ, 12 May 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
