1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: [Ext]How to use Optics Slit records with absolute encoders?
From: Jesse Hopkins via Tech-talk <[email protected]>
Date: Thu, 15 May 2025 16:28:36 +0000
Hi Mark,
Thanks, that’s exactly what I needed!
All the best.
- Jesse
Jesse Hopkins, PhD (he/him)
Director, BioCAT
Sector 18, Advanced Photon Source
Research Associate Professor, Illinois Tech
Date: Thursday, May 15, 2025 at 10:21
 AM
To: Jesse Hopkins <[email protected]>
Cc: [email protected] <[email protected]>
Jesse,
The motor record does change the OFF field and not DVAL as long as you set the FOF field to Variable.
Sent from my iPhone
On May 15, 2025, at 10:12 AM, Jesse Hopkins via Tech-talk <[email protected]> wrote:
Hi Mark,
Thanks for the suggestion, the offset parameter is quite useful here (even in just getting the scales to agree, since the vendor seems to have applied them a bit inconsistently). A few months ago I did set up some slit pseudomotors with the CSAxes in the GALIL, and it worked. What I ran into however is that the ease of use wasn’t great, as setting slit size and position values required manually setting component motor positions (in this case I’d have to do it via the offsets). Since I’m not doing fly scans or similar with the slits, precise synchronization isn’t as important for me, and the Optics module Slit records provided a high convenience level.
I guess the follow on based on what you said is whether there’s a way to get the motor record with absolute encoders to change the offset value when the position is set, so that standard approaches would work in a transparent fashion?
All the best.
- Jesse
Director, BioCAT
From: Tech-talk <[email protected]> on behalf of Mark via Tech-talk <[email protected]>
Date: Wednesday, May 14, 2025 at 9:46
 PM
To: [email protected] <[email protected]>
Subject: [Ext]How to use Optics Slit records with absolute encoders?
Hi Jesse,
To move the motor record readback for an axis using an absolute encoder,
the motor record OFF field can be used.
Here is a short example.
1.  Move the motor to beam centre.
2.  Adjust motor record OFF until the readback becomes 0
CSAxis will provide greater motor synchronicity over the slits
database.  Note the Galil EPICS driver supports the motor record OFF
field for GalilAxis (real motors), but not for GalilCSAxis (coordinate
system motors).
Kind regards,
Mark Clift.
This email has been checked for viruses by AVG antivirus software.
https://urldefense.us/v3/__http://www.avg.com__;!!G_uCfscf7eWS!YBgqaoy--IyCNu2i8kLVYn1yIwe2L6GC3GyUOx5TfHSKDbFBAKaSghyC8QJZVg5TOnjGA-43tIIvYiKmtE0$
How to use Optics Slit records with absolute encoders? Mark via Tech-talk
Re: [Ext]How to use Optics Slit records with absolute encoders? Jesse Hopkins via Tech-talk
Re: [Ext]How to use Optics Slit records with absolute encoders? Mark Rivers via Tech-talk
Prev: Re: [Ext]How to use Optics Slit records with absolute encoders? Mark Rivers via Tech-talk
Next: A $ in a PV name? Brown, Garth via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: camonitor the PACT field Neidherr, Dennis Dr. via Tech-talk
