1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Diagnosing and overcoming GigE camera freezes
From: Heinz Junkes via Tech-talk <[email protected]>
To: "Henrique F. Simoes" <[email protected]>
Cc: Eduardo Pereira Coelho <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 23 May 2025 10:08:56 +0200
Hallo Henrique,
We have also been using GigE cameras with our Free Elektron Laser for >10 years (Prosilica, now Allied Vision).
We have strong radiation when operating the system. This 'destroys' the camera very quickly when the camera
is active (half-life of the cameras << 1 year).
We can switch the power supply to the cameras on/off remotely via EPICS-PV (home-made boxes, connected to digital I/O Omron PLC ).
We only use the cameras for startup ('threading the beam’).
Continuous operation of the cameras has never been possible for us. We tried it in the first year. However, we felt we had to replace all the cameras at least once in this Year.
We had also noticed the phenomenon of freezing. Our camera network is separate and powerful enough to operate all cameras simultaneously (approx. 20 cameras).
Heinz
> On 22. May 2025, at 21:04, Henrique F. Simoes via Tech-talk <[email protected]> wrote:
> Dear tech-talkers,
> In recent years, we at LNLS have faced some issues with Basler GigE cameras
> suddenly freezing, which are used for electron and photon beam visualization.
> In a typical scenario, the camera suddenly won't answer anything in its network
> interface, including ICMP (ping) and GVCP discovery packets (sent by the Aravis
> tool). This has shown to occur both in the accelerator and beamlines. The only
> way we know to recover from this situation is to power cycle the device.
> In the accelerator, where this happens more often, we power them with PoE Aruba
> switches, which enables us to power cycle them remotely through an SMNP-based
> IOC. In the beamlines, the situation is more uncomfortable: we power them with
> PoE injectors because the switches aren't PoE. This means a human must
> interfere, which makes the experience even worse.
> I don't think that's something only happening to us, as I've seen some mentions
> of cameras freezing in the accelerator community. In a response to a question
> related to the aforementioned Aruba switch IOC [1], John Priller mentioned that
>> We use the package to communicate with ISEG power supply crates, and remote
>> power-distribution units providing power on/off switching for things like
>> cameras that sometimes hang up due to magnetic fields or neutrons or etc in
>> our accelerator
> Evan Daykin also reported this in ADAravis [2].
> In the last EPICS Collab Meeting, Chris Gregory presented us their challenges
> at the STFC Central Laser Facility [3], which included a mention to
>> The camera IOC needs re-start because the IOC gets frozen after 4/5 days of
>> acquiring the image.
> So here goes my questions to you. If you faced similar issues in the past, what
> did you do to diagnose it and overcome it? If you still face them, how do you
> deal with it? If you use GigE cameras and never had such issues, which camera
> model do you use and in which environment?
> We are still investigating whether halts correlate with the camera temperature
> right before it happens, which is one of our current hypotheses. Another is the
> possibly high incoming traffic in its network interface (e.g. EPICS
> broadcasts), which we've seen lead to problems on Galil controllers in the
> past.
> Changing the manufacturer is another ongoing discussion internally, which aims
> to change the situation somehow. Any recommendation in this direction is very
> welcome as well. I've seen an older thread on this topic [4], but some models
> are no longer available, and I expect things to have changed after 7 years.
> Thanks in advance for any comments.
> [1] epics.anl.gov/tech-talk/2024/msg00890.php
> [2] github.com/areaDetector/ADAravis/issues/21
> [3] indico.stfc.ac.uk/event/1233/contributions/8412/
> [4] epics.anl.gov/tech-talk/2018/msg01918.php
> Henrique F. Simões
> Control Software Group (SwC)
> Brazilian Synchrotron Light Laboratory (LNLS)
> Brazilian Center for Research in Energy and Materials (CNPEM)
> Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
> Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
Attachment: smime.p7s
Description: S/MIME cryptographic signature
Re: Diagnosing and overcoming GigE camera freezes Henrique F. Simoes via Tech-talk
Prev: Re: Diagnosing and overcoming GigE camera freezes John Dobbins via Tech-talk
Next: EPICS Channel Access UDP Processing Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Re: Diagnosing and overcoming GigE camera freezes Henrique F. Simoes via Tech-talk
