1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: aai to multiple states
From: "Dr. Simon Friederich via Tech-talk" <[email protected]>
Date: Wed, 4 Jun 2025 09:25:17 +0200
Dear Marcio and Ziga,
ah I see. Thanks for pointing this out! I've accidently read over "the 9 bi records" from your answer, Ziga. I thought there might be a hidden "string" label for the bit fields for a mbbiDirect record.
Ok, then I go with the individual bi records with DESC and the labels. As all "bi"s will have same labels I wanted to use my application example to learn whether there might be another possible solution, because I often come across it. (talking about mbbi and mbbiDirect records).
Best regards
Simon
aai to multiple states Dr. Simon Friederich via Tech-talk
RE: aai to multiple states Žiga Oven via Tech-talk
Prev: Re: aai to multiple states Paduan Donadio, Marcio via Tech-talk
Next: Re: Eaton UPS Network-M3 boj via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Inquiry About EPICS Support for XILINX XDMA PCIe Driver hzx1997--- via Tech-talk
