1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: StreamDevice and libpcre2
From: Jörn Dreyer via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 05 Jun 2025 09:09:18 +0200
Hi everybody,
I faced today the fact that on my system (OpenSuSE Tumbleweed) there is no libpcre anymore. It got replaced completely by its successor libpcre2.
I came across that when trying to recompile my EPICS installation. It failed when building StreamDevice.
Now there are three options how to solve that:
1) Install the old libpcre 8.45 from source by hand in the system. Might still work for some time, but what when not? It has not been updated since 2021
and might contain bugs and security issues that will not be fixed.
2) Install libpcre as part of StreamDevice. It faces the same problems as above.
3) Port StreamDevice to libpcre2. That would make it future prove and more easy to maintain.
For me #1 is only a short term solution. For now only my OpenSuSE system is affected and I can build a package for that, but what when systems like Debian/Ubuntu arfe affected?
As I use E3 to deploy my EPICS installations now, I could setup an installation of libpcre for that, but it would require to fork the e3-StreamDevice wrapper from ESS
to add the pcre module dependency. I would prefer not to do that as it could make things incompatible at some time.
So this leaves #3 as the optimal solution an I would like to know if somebody has already looked into that or is actively working on it.
Jörn
Re: StreamDevice and libpcre2 Ralph Lange via Tech-talk
RE: StreamDevice and libpcre2 Zimoch Dirk via Tech-talk
Prev: Re: Eaton UPS Network-M3 boj via Tech-talk
Next: Re: StreamDevice and libpcre2 Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Inquiry About EPICS Support for XILINX XDMA PCIe Driver Joao Paulo Martins via Tech-talk
