1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Retiga E7 and ADKinetix
From: John Dobbins via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>, "Wlodek, Jakub" <[email protected]>
Date: Thu, 12 Jun 2025 14:19:05 +0000
I have the latest ADKinetix source code.
I modified ADKinetix::ADKinetix  to just retrieve the camera name, following
/opt/pvcam/sdk/examples/code_samples
However, the returned name is nonsense. Each run returns a different nonsense result. This was true before my modifications also.
I then did the following:
I verify that I can successfully run
/opt/pvcam/sdk/examples/code_samples/bin/linux-x86_64/release/FanSpeedAndTemperature
Then I copied the example source files
FanSppecandTemperature.cpp
Common.cpp
Common.h
version.h
to
ADKinetix/kinetixApp/src
And I add these lines to the Makefile
PROD_HOST += FanSpeedAndTemperature
FanSpeedAndTemperature_LIBS += pvcam
FanSpeedAndTemperature_SRCS += FanSpeedAndTemperature.cpp
FanSpeedAndTemperature_SRCS += Common.cpp
Which builds FanSpeedAndTemperature  using the EPICS build system
The version of FanSpeedAndTemeprature built in this way has the same behavior, outputs a random nonsense name
PVCAM initialized
Number of cameras found: 1
Camera 0 name: '��b"�'
I don't know how to proceed. Any advice appreciated.
John
From: Tech-talk <[email protected]> on behalf of John Dobbins via Tech-talk <[email protected]>
Sent: Tuesday, June 10, 2025 12:31 PM
Subject: Retiga E7 and ADKinetix
I have a new  Teledyne Retiga E7.
I first tested on windows using the PVCAM software and the Beacon software.
Next on Linux, Alma 9,  I verified that /opt/pvcam/bin/PVCamTest/x86_64/'PVCanTestCli   succeeds.
Then using ADKinetix R1-1,  base-7.0.6 , areaDetector-R3-13  I get a segfault  (see below)
What should I do next?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
[root@lnx591 iocKinetix]# ../../bin/linux-x86_64/kinetixApp st.cmd
#!../../bin/linux-x86_64/kinetixApp
< /epics/common/xf31id1-lab3-ioc1-netsetup.cmd
Can't open /epics/common/xf31id1-lab3-ioc1-netsetup.cmd: No such file or directory
errlogInit(20000)
< envPaths
epicsEnvSet("IOC","iocKinetix")
epicsEnvSet("TOP","/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADKinetix/iocs/kinetixIOC")
epicsEnvSet("ADKINETIX","/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADKinetix/iocs/kinetixIOC/../..")
epicsEnvSet("SUPPORT","/nfs/chess/epics/det/support_alma")
epicsEnvSet("ASYN","/nfs/chess/epics/det/support_alma/asyn-R4-45")
epicsEnvSet("AREA_DETECTOR","/nfs/chess/epics/det/support_alma/areaDetector-R3-13")
epicsEnvSet("ADSUPPORT","/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADSupport")
epicsEnvSet("ADCORE","/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADCore")
epicsEnvSet("AUTOSAVE","/nfs/chess/epics/det/support_alma/autosave-R5-11")
epicsEnvSet("BUSY","/nfs/chess/epics/det/support_alma/busy-R1-7-4")
epicsEnvSet("CALC","/nfs/chess/epics/det/support_alma/calc-R3-7-5")
epicsEnvSet("SNCSEQ","/nfs/chess/epics/det/support_alma/seq-R2-2-9")
epicsEnvSet("SSCAN","/nfs/chess/epics/det/support_alma/sscan-R2-11-5")
epicsEnvSet("DEVIOCSTATS","/nfs/chess/epics/det/support_alma/iocStats-3-1-16")
epicsEnvSet("EPICS_BASE","/nfs/chess/epics/det/base-7.0.6")
dbLoadDatabase("/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADKinetix/iocs/kinetixIOC/dbd/kinetixApp.dbd")
kinetixApp_registerRecordDeviceDriver(pdbbase)
# Prefix for all records
epicsEnvSet("PREFIX", "RE7")
# The port name for the detector
epicsEnvSet("PORT",   "KTX")
# The queue size for all plugins
epicsEnvSet("QSIZE",  "20")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/nfs/chess/epics/det/support_alma/areaDetector-R3-13/ADCore/db")
ADKinetixConfig(0, "KTX")
Segmentation fault (core dumped)
Re: Retiga E7 and ADKinetix John Dobbins via Tech-talk
Prev: Re: Modbus write/read data error help. Mark Rivers via Tech-talk
Next: Re: Retiga E7 and ADKinetix John Dobbins via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Retiga E7 and ADKinetix Wlodek, Jakub via Tech-talk
