Dear Muhammad,
I can answer your first question.
I wrote a driver for the ZWO cameras for a projekt with special needs. As these cameras do not have a hardware trigger
the code contains currently some pieces that refer to special hardware that we tested to get a trigger into our PC.
I need to prepare a cleaned up version for publication.
Do you need the camera to be triggered by hardware or is a software trigger good enought for your project?
Regards
Jörn
Am Freitag, 13. Juni 2025, 04:59:57 Mitteleuropäische Sommerzeit schrieb Muhammad Septyawan Aulia via Tech-talk:
> Dear EPICS Community,
> Good day.
> I am relatively new to both EPICS and areaDetector, though I have some prior experience developing EPICS applications using StreamDevice and Modbus. Currently, I am working on a project involving an X-ray CT system that will utilize a [ https://urldefense.us/v3/__https://www.zwoastro.com/product/asi183/__;!!G_uCfscf7eWS!bsrNSgCMR687vVBeqLhi-wLzJ3EnacBvrFePfSFQxZGokKGigO_4TEM2MICadEXPpGeHUvc2Malulb5pGhcLIAo$ | ZWO ASI183MM Pro ] camera, and I would like to integrate it using areaDetector.
> To help me get started, I would greatly appreciate any guidance on the following:
> 1.
> Are there existing areaDetector drivers or modules that support the ZWO ASI183MM Pro camera?
> 2.
> Could you recommend any resources or tutorials could follow for areaDetector?
> Thank you in advance for your time and expertise. I truly appreciate any advice or pointers you can provide.
> Best regards,
> Septyawan Aulia
- Re: areaDetector for ZWO ASI 183MM Pro Muhammad Septyawan Aulia via Tech-talk
- areaDetector for ZWO ASI 183MM Pro Muhammad Septyawan Aulia via Tech-talk
<2025>
2026
<2025>
2026
