1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025 Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
Subject: Channel Finder Recsync Server issue
From: hanr shayi via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Fri, 20 Jun 2025 08:37:44 +0800
hi,
I am using channel finder, when I try "curl "http://localhost:8080/ChannelFinder/resources/channels?~name=*"", it can return messages like:
[{"name":"testcf:Msg-I","owner":"myself","properties":[{"name":"hostName","owner":"admin","value":"cow4","channels":[]},{"name":"iocName","owner":"admin","value":"41280","channels":[]},{"name":"iocid","owner":"admin","value":"172.21.0.1:41280","channels":[]},{"name":"iocIP","owner":"admin","value":"172.21.0.1","channels":[]},{"name":"pvStatus","owner":"admin","value":"Active","channels":[]},{"name":"time","owner":"admin","value":"2025-06-17 01:41:37.289733","channels":[]},{"name":"recceiverID","owner":"admin","value":"87eba2618c13","channels":[]},{"name":"recordType","owner":"admin","value":"stringin","channels":[]}],"tags":[]},{"name":"testcf:State-Sts","owner":"myself","properties":[{"name":"hostName","owner":"admin","value":"cow4","channels":[]},{"name":"iocName","owner":"admin","value":"41280","channels":[]},{"name":"iocid","owner":"admin","value":"172.21.0.1:41280","channels":[]},{"name":"iocIP","owner":"admin","value":"172.21.0.1","channels":[]},{"name":"pvStatus","owner":"admin","value":"Active","channels":[]},{"name":"time","owner":"admin","value":"2025-06-17 01:41:37.289733","channels":[]},{"name":"recceiverID","owner":"admin","value":"87eba2618c13","channels":[]},{"name":"recordType","owner":"admin","value":"mbbi","channels":[]}],"tags":[]},{"name":"testcf:ai:archive","owner":"myself","properties":[{"name":"hostName","owner":"admin","value":"cow4","channels":[]},{"name":"iocName","owner":"admin","value":"41280","channels":[]},{"name":"iocid","owner":"admin","value":"172.21.0.1:41280","channels":[]},{"name":"iocIP","owner":"admin","value":"172.21.0.1","channels":[]},{"name":"pvStatus","owner":"admin","value":"Active","channels":[]},{"name":"time","owner":"admin","value":"2025-06-
if I try to filter the properity like this : curl "http://localhost:8080/ChannelFinder/resources/channels?~name=*&~prop=recordType:longout"
it will return just "[]".
I have add:
alias = on
recordType = on
recordDesc = on
in configurations.
Can anybody give me suggestions? thanks a lot in advance.
Best wishes
Shayi 2025/06/19
Re: Channel Finder Recsync Server issue Tynan Ford via Tech-talk
Prev: Re: Question about getting hexadecimal data with StreamDevice Mark Rivers via Tech-talk
Next: Re: Channel Finder Recsync Server issue Tynan Ford via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025
ANJ, 20 Jun 2025 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
