1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: [EXTERNAL] Problems with the alarm-server and large number of channels
From: Charles Jenkins via Tech-talk <[email protected]>
To: "Hartman, Steven" <[email protected]>
Cc: Phoebus Tech Talk <[email protected]>
Date: Thu, 26 Jun 2025 14:05:49 -0500
Hello Steven,
I only have one IOC and it is running on the same computer for this simulated system.  The second link (org.phoebua.pv.ca/addr_list") broken.
Merrill Jenkins
On 6/26/2025 9:43 AM, Hartman, Steven wrote:
Hi Merrill—
Are both of your IOCs running on the same computer, and are you using that server’s IP address to specify the CA address list for your Phoebus configuration?
I suspect the problem may be your channel access network configuration. See https://docs.epics-controls.org/en/latest/sys-admin/configure-ca.html for "Multiple IOCs on the same computer”.
The simplest solution is to specify a broadcast address instead. I believe the relevant phoebus preference is "org.phoebus.pv.ca/addr_list"
Steven Hartman
On Jun 26, 2025, at 10:01 AM, Charles Jenkins via Tech-talk <[email protected]> wrote:
This Message Is From an External Sender
This email was sent from a non-ORNL address. If suspicious, use the Report Phish button in Outlook.
Hello Everyone,
I am working on setting up the Phoebus alarm-server for the Mu2e
experiment.
I have a simulated EPICS IOC that I use to develop a Phoebus
alarm-server (this includes setting up zookeeper and kafka).  I have
been able to successfully set up the alarm server for one large
sub-system, but when I add a second large sub-system I get
"UNDEFINED/Disconnected" messages for process variables on the alarm
tree and "UNDEFINED" for these process variables in the alarm table.  If
I include just one of these large subsystems I do not get these
messages.  Messages from the alarm-server itself says "connection timed
out" for the channels.  If I type "ls" in the alarm-server terminal,
these alarm topics say "UNDEFINED" . Meanwhile a "caget"of channels from
EPICS (the simulated IOC) gives values that I had set previously before
starting the alarm-server and Phoebus.
Can anyone provide a clue as to what I am not setting up correctly?
Merrill Jenkins
Merrill Jenkins
Professor of Physics
==== Mailing Address ====
Physics
411 University Blvd. N.
MSPB RM 115
Mobile, AL 36688
phone 251.414.8013
Dept: 251.460.6224
Fax:  251.460.6800
Merrill Jenkins
Physics
MSPB RM 115
Mobile, AL 36688
phone 251.414.8013
Dept: 251.460.6224
Fax:  251.460.6800
Problems with the alarm-server and large number of channels Charles Jenkins via Tech-talk
Re: [EXTERNAL] Problems with the alarm-server and large number of channels Hartman, Steven via Tech-talk
Prev: Re: "Inject" code into IOC startup files? Han Lee via Tech-talk
Next: Re: Channel Finder Recsync Server issue hanr shayi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: [EXTERNAL] Problems with the alarm-server and large number of channels Hartman, Steven via Tech-talk
Next: Generation of state diagram documentation from SNL Ed Janke via Tech-talk
