1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: How to run the Phoebus alarm-server demo
From: Charles Jenkins via Tech-talk <[email protected]>
To: Phoebus Tech Talk <[email protected]>
Date: Fri, 27 Jun 2025 13:45:30 -0500
Hello All,
I am setting up the Phoebus-based Global Alarms for the Mu2e experiment.  I can get the alarm-server to work for a limited number of Process Variables.  But as I add systems, I get time-out and disconnect messages.  Individually, these will run, but when I combine systems, I get this error.
I generate ".xml" files that I import into the alarm-server.  I see from the documentation that it is possible to have a config with 100k Process Variables... So I suspect I am setting up the ".xml" files wrong.   What I have done to include the multiple systems is use a series of ".xml" files that use the "xinclude" feature to include other files.   Is that correct?  Or should I use one large file with all Process variables and components for branches in the alarm tree?
Also, I thought I could set up the demos to see the structure of the ".xml" file and see what I could be doing wrong.    However, I don't see from the instructions on how to run the demo programs that are built.  Could someone tell me how to run the alarm demos?
Thanks for any help.
Merrill Jenkins
Merrill Jenkins
Professor of Physics
==== Mailing Address ====
Physics
411 University Blvd. N.
MSPB RM 115
Mobile, AL 36688
phone 251.414.8013
Dept: 251.460.6224
Fax:  251.460.6800
Prev: Re: Generation of state diagram documentation from SNL Ed Janke via Tech-talk
Next: Issues with drvAsynIPServerPort for UDP Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: AreaDetector Collaboration Meeting - July 3rd Érico Nogueira Rolim via Tech-talk
