1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Strange Make Error
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Torsten Bögershausen <[email protected]>, Federico Galdenzi <[email protected]>, Simon Rose <[email protected]>
Date: Mon, 21 Jul 2025 16:07:47 +0000
I agree that this has nothing to do with the EPICS code.
Another possibility is that the machine that you used to extract or checkout the EPICS code has its clock far in advance of the machine where you’re doing the build. The GNUmake program that we use to build EPICS does need all of your machine clocks to be closely synchronized, you can’t rely on manually setting the clocks if you’re going to use more than one system to extract and do the builds.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 7/21/25, 11:02 AM, "Tech-talk" <[email protected]> wrote:
Hej Federico,
As far as I can see :this has nothing to do with C
The time of your local machine compared to the time where
/home/xlabsrv11/ is mounted are really out of sync.
Either the clock of your local machine is wrong.
Or the server hosting the file system has the wrong clock.
Or both.
What happens, if you enter
date
on your machine ?
On 2025-07-21 17:24, Federico Galdenzi via Tech-talk wrote:
> Dear Simon,
> Thanks for the reply. I'm not very familiar with C but i'm trying to
> fill the gaps. However the building fails because the warning gets
> triggered continously and the building doesnt' go further. It just keeps
> printing the warning.
> Il 2025-07-21 16:33 Simon Rose ha scritto:
>> Hi Federico -
>> Make uses the timestamp on files to detect if a file needs to be
>> updated. It seems that one of your files thinks it was created about 6
>> years from now.
>> I've seen this come up in a few odd ways, possibly due to thinks like
>> mounted filesystems on hosts that have different time settings, or
>> improper NTP syncing.
>> That said, that shouldn't actually cause the build to fail; that's
>> just a warning that something is a bit off with the latest
>> modification time of that file. It can be ignored, although it's
>> probably worth looking at why your file and systems times do not match
>> each other.
>> Cheers,
>> Simon
>> On 2025-07-21, 16:17, "Tech-talk on behalf of Federico Galdenzi via
>> Tech-talk" <[email protected] <mailto:tech-talk-
>> [email protected]> on behalf of [email protected] <mailto:tech-
>> [email protected]>> wrote:
>> Dear Community,
>> I'm trying to learn EPICS and i started following a pretty simple
>> example from Maurizio Monti, stream device exercises. I wanted to create
>> a simple EPICS application that controls VPS. However, after setting up
>> everything, I get into this error.
>> make[3]: Attenzione: il file
>> "/home/xlabsrv11/epics/configure/RULES_COMMON" ha un orario di modifica
>> 209019432 nel futuro
>> Creating dbd file hvps_example.dbd
>> perl -CSD /home/xlabsrv11/epics/bin/linux-x86_64/dbdExpand.pl -I. -I..
>> -I../O.Common -I../../../dbd
>> -I/home/xlabsrv11/epics/synApps_6_3/support/asyn-R4-44-2/dbd
>> -I/home/xlabsrv11/epics/synApps_6_3/support/StreamDevice-2-8-24/dbd
>> -I/home/xlabsrv11/epics/dbd -o hvps_example.dbd base.dbd
>> ^Cmake[2]: *** [/home/xlabsrv11/epics/configure/RULES_ARCHS:58:
>> install.linux-x86_64] Interruzione
>> make[1]: *** [/home/xlabsrv11/epics/configure/RULES_DIRS:85:
>> src.install] Interruzione
>> make: *** [/home/xlabsrv11/epics/configure/RULES_DIRS:85:
>> hvps_exampleApp.install] Interruzione
>> The "make[3]: warning" translates to " the file ../../.. has a different
>> modification time 209019432 in the future".
>> Can you help me?
>> ps: as a side note, i'd like to know if you can suggest me some
>> resources for learning epics. I'm kinda lost sometimes.
Re: Strange Make Error Maren Purves via Tech-talk
Strange Make Error Federico Galdenzi via Tech-talk
Re: Strange Make Error Simon Rose via Tech-talk
Re: Strange Make Error Federico Galdenzi via Tech-talk
Re: Strange Make Error Torsten Bögershausen via Tech-talk
Prev: Re: Strange Make Error Érico Nogueira Rolim via Tech-talk
Next: Re: Strange Make Error Maren Purves via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Strange Make Error Torsten Bögershausen via Tech-talk
