Thanks Matt, it is exactly what I need, but it is still unclear how it interfaces with my existing waveform record, i.e. How to pass
data from my waveform record to $(P)$(R)ArrayIn. My waveform record already has its INP field set to read input from a compress record doing circular buffer at 200 Hz from the hardware.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Hi Abdalla,
This might be what you need:
https://areadetector.github.io/areaDetector/NDDriverStdArrays/NDDriverStdArraysDoc.html
It monitors a waveform record and can turn it into an NDArray, which can then be processed by other areaDetector plugins as needed. It doesn’t connect to the Asyn port that is producing the waveform data
directly, but instead sets up a channel access monitor.
Cheers,
Matt
On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Monday, July 21, 2025 3:14 AM
To: [email protected]
Subject: [EXTERNAL] Using AD plugins on asyn port
Hi Is there a way to apply AD plugins on a waveform record processed from asyn port without rewriting an asynNDArrayDriver class? i. e. , something
to be done in the st. cmd maybe? Best Regards, Abdalla Al-Dalleh Control Engineer SESAME
Hi
Is there a way to apply AD plugins on a waveform record processed from asyn port without rewriting an asynNDArrayDriver class? i.e., something to be done in the st.cmd maybe?
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
