Hi All,
I am trying to get a Micronix MMC-100 IOC running and while I can connect to it and move the axes, the position is not right and I think it may be due to the controller not being set to a MMC-100. I am not sure though. When I start the IOC I see this message: 2025/07/24 18:17:42.839 MMC200Axis::MMC200Axis: version string is invalid. This is my st.cmd #!/opt/epics/synApps_6.1/support/motor-R7-2-2/modules/motorMicronix/iocs/micronixIOC/bin/linux-x86_64/micronix cd /opt/iocs/micronix/iocBoot < envPaths ## Register all support components dbLoadDatabase "/opt/epics/synApps_6_1/support/motor-R7-2-2/modules/motorMicronix/iocs/micronixIOC/dbd/micronix.dbd" micronix_registerRecordDeviceDriver pdbbase ## motorUtil (allstop & alldone) dbLoadRecords("$(MOTOR)/db/motorUtil.db", "P=micronix:") ## < motor.cmd.mmc200 #log debug output to file streamSetLogfile StreamDebug.log iocInit ## motorUtil (allstop & alldone) motorUtilInit("micronix:") var streamDebug 1 # Boot complete This is my substitutions file: file "$(MOTOR)/motorApp/Db/asyn_motor.db" { pattern {P, M, DTYP, PORT, ADDR, DESC, EGU, DIR, VMAX, VELO, VBAS, ACCL, BDST, BVEL, BACC, MRES, PREC, DHLM, DLLM, INIT} {end1:, x, "asynMotor", mmc200_1, 0, "m1x", mm, Pos, 3., 1., .05, .5, 0, 1.0, 2, 1e-6, 5, 0, 0, ""} {end1:, y, "asynMotor", mmc200_1, 1, "m1y", mm, Pos, 3., 1., .05, .5, 0, 1.0, 2, 1e-6, 5, 0, 0, ""} {end2:, x, "asynMotor", mmc200_1, 2, "m2x", mm, Pos, 3., 1., .05, .5, 0, 1.0, 2, 1e-6, 5, 0, 0, ""} {end2:, y, "asynMotor", mmc200_1, 3, "m2y", mm, Pos, 3., 1., .05, .5, 0, 1.0, 2, 1e-6, 5, 0, 0, ""} {end3:, x, "asynMotor", mmc200_1, 4, "m3x", mm, Pos, 3., 1., .05, .5, 0, 1.0, 2, 1e-6, 5, 0, 0, ""} {end3:, y, "asynMotor", mmc200_1, 5, "m3y", mm, Pos, 3., 1., .05, .5, 0, 1.0, 2, 1e-6, 5, 0, 0, ""} } and this is my motor.cmd.mmc200 dbLoadTemplate("motor.substitutions.mmc200") ### RS-232 with RS-485 adpater (serial1) drvAsynSerialPortConfigure("serial1", "/dev/ttyUSB0", 0, 0, 0) asynSetOption ("serial1", 0, "baud", "38400") #asynSetOption ("serial1", 0, "baud", "115200") asynSetOption ("serial1", 0, "bits", "8") asynSetOption ("serial1", 0, "parity", "none") asynSetOption ("serial1", 0, "stop", "1") asynSetOption ("serial1", 0, "clocal", "Y") #asynSetOption ("serial1", 0, "crtscts", "N") asynOctetSetInputEos("serial1",0,"\r") asynOctetSetOutputEos("serial1",0,"\r") MMC200CreateController("mmc200_1", "serial1", 6, 500, 2000, 1) # Turn off asyn traces #!asynSetTraceIOMask("serial1",0,0x0) #!asynSetTraceMask("serial1",0,0x1) output from ./st.cmd #!/opt/epics/synApps_6.1/support/motor-R7-2-2/modules/motorMicronix/iocs/micronixIOC/bin/linux-x86_64/micronix cd /opt/iocs/micronix/iocBoot < envPaths epicsEnvSet("IOC","iocMicronix") epicsEnvSet("TOP","/opt/epics/synApps/support/motor-R7-2-2/modules/motorMicronix/iocs/micronixIOC") epicsEnvSet("MOTOR","/opt/epics/synApps/support/motor-R7-2-2") epicsEnvSet("ASYN","/opt/epics/synApps/support/asyn-R4-36") epicsEnvSet("SNCSEQ","/opt/epics/synApps/support/seq-2-2-6") epicsEnvSet("BUSY","/opt/epics/synApps/support/busy-R1-7-2") epicsEnvSet("IPAC","/opt/epics/synApps/support/ipac-2-15") epicsEnvSet("EPICS_BASE","/opt/epics/base") ## Register all support components dbLoadDatabase "/opt/epics/synApps_6_1/support/motor-R7-2-2/modules/motorMicronix/iocs/micronixIOC/dbd/micronix.dbd" micronix_registerRecordDeviceDriver pdbbase Warning: IOC is booting with TOP = "/opt/epics/synApps/support/motor-R7-2-2/modules/motorMicronix/iocs/micronixIOC" but was built with TOP = "/opt/epics/synApps_6.1/support/motor-R7-2-2/modules/motorMicronix/iocs/micronixIOC" ## motorUtil (allstop & alldone) dbLoadRecords("/opt/epics/synApps/support/motor-R7-2-2/db/motorUtil.db", "P=micronix:") ## < motor.cmd.mmc200 dbLoadTemplate("motor.substitutions.mmc200") ### RS-232 with RS-485 adpater (serial1) drvAsynSerialPortConfigure("serial1", "/dev/ttyUSB0", 0, 0, 0) #drvAsynSerialPortConfigure("serial1", "/dev/ttymmc1", 0, 0, 0) #drvAsynSerialPortConfigure("serial1", "/dev/ttyUSB2", 0, 0, 0) #drvAsynSerialPortConfigure("serial1", "/dev/ttyUSB1", 0, 0, 0) asynSetOption ("serial1", 0, "baud", "38400") #asynSetOption ("serial1", 0, "baud", "115200") asynSetOption ("serial1", 0, "bits", "8") asynSetOption ("serial1", 0, "parity", "none") asynSetOption ("serial1", 0, "stop", "1") asynSetOption ("serial1", 0, "clocal", "Y") #asynSetOption ("serial1", 0, "crtscts", "N") asynOctetSetInputEos("serial1",0,"\r") asynOctetSetOutputEos("serial1",0,"\r") MMC200CreateController("mmc200_1", "serial1", 6, 500, 2000, 1) 2025/07/24 18:22:27.003 MMC200Axis::MMC200Axis: version string is invalid. 2025/07/24 18:22:27.067 MMC200Axis::MMC200Axis: version string is invalid. 2025/07/24 18:22:27.131 MMC200Axis::MMC200Axis: version string is invalid. 2025/07/24 18:22:27.195 MMC200Axis::MMC200Axis: version string is invalid. 2025/07/24 18:22:27.259 MMC200Axis::MMC200Axis: version string is invalid. 2025/07/24 18:22:27.323 MMC200Axis::MMC200Axis: version string is invalid. # Turn off asyn traces #!asynSetTraceIOMask("serial1",0,0x0) #!asynSetTraceMask("serial1",0,0x1) #log debug output to file streamSetLogfile StreamDebug.log st.cmd line 20: Command streamSetLogfile not found. iocInit Starting iocInit ############################################################################ ## EPICS R7.0.5 ## Rev. 2024-10-30T19:45+0000 ############################################################################ cas warning: Configured TCP port was unavailable. cas warning: Using dynamically assigned TCP port 35877, cas warning: but now two or more servers share the same UDP port. cas warning: Depending on your IP kernel this server may not be cas warning: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST) iocRun: All initialization complete ## motorUtil (allstop & alldone) motorUtilInit("micronix:") var streamDebug 1 Var streamDebug not found. # Boot complete Could it just be my MRES value? Or is the MMC100 not being identified correctly? Or something else? Thanks, Jeff
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
