On 7/31/25 06:24, Wells, Alex
(DLSLtd,RAL,LSCI) via Tech-talk wrote:
Hi Tech Talk,
I'm currently trying to build what is in effect two IOCs inside
one EPICS folder structure. This is to allow a shared EPICS
configuration folder (and various scripts), but keeping the two
IOC builds separate inside their own "App" folders.
This works quite well for the executables as I can use the
"TESTPROD_IOC" variable, which causes the executables to only be
built into the "App/src/O.$(T_A)" directory. However, there is
no similar variable for DB or DBD. This results in my top level
directory ending up with "db" and "dbd" folders, full of built
files from both my IOCs which I do not want. Especially as some
file names conflict and they override eachother.
Is there any way to modify the Makefiles to stop this behaviour?
For .dbd files, there is a pattern involving $(TARGETS) and
$(DBDDEPENDS_FILES).
https://github.com/epics-base/epics-base/blob/007df69726ae6c7711985a59491f078b7b55dab5/modules/database/test/std/rec/Makefile#L23-L26
- Stopping DB and DBD files being copied to top level Wells, Alex (DLSLtd,RAL,LSCI) via Tech-talk
Re: Stopping DB and DBD files being copied to top level Johnson, Andrew N. via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
