1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Announcing linStat 1.0.0
From: Michael Davidsaver via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 13 Aug 2025 11:38:37 -0700
"linStat" is an epics support module I have worked on for the past year or so.
It is meant to be a Linux-only alternative to iocStats, providing much more
depth than iocStats, at the cost of being highly OS specific.
The extra information includes:
- swap usage and page fault counters
- CPU usage, including time spent in ISR
- Forced context switch counters
- IP package counters, system-wide and per-interface
- File system usage
- malloc() stats
- Maximum temperature and sensor name
For example, network packet counters, page fault counts, and maximum temperature.
It also installs separate database files for host, IOC process, file system, and
network interface.
Where there is overlap, linStat provides the same record names as iocStats.
https ://github.com/mdavidsaver/linStat
A previous mention on core-talk: https ://epics.anl.gov/core-talk/2025/msg00082.php
Prev: Re: synchronizing the value of a read/write record Johnson, Andrew N. via Tech-talk
Next: Re: Mapping customised pva structures to epics v4 Normative Types and v3 PVs (channel access). Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Modbus asyn issue with RS485 connection (maybe hardware related) Heinz Junkes (FHI) via Tech-talk
Next: Can't use BayerRG8 pixel format with ADSpinnaker Jesse Hopkins via Tech-talk
