1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Can't use BayerRG8 pixel format with ADSpinnaker
To: Jesse Hopkins <[email protected]>
Cc: Tech-Talk EPICS <[email protected]>
Date: Thu, 14 Aug 2025 18:48:55 +0000
You are using the wrong medm screen. You should be using ADSpinnker.adl,  not ADGenICam which does not support ConvertPixelFormat.
Sent from my iPhone
On Aug 14, 2025, at 10:47 AM, Jesse Hopkins via Tech-talk <[email protected]> wrote:
Hi folks,
I’m attempting to use a FLIR Blackfly BFS-PGE-23S6C camera with the ADSpinnaker EPICS support. Mostly I’ve been able to get it set up just fine. However, the only pixel formats that seem to work with the camera are Mono8, Mono16, and RGB8Packed. The trouble I’m running into is that RGB8Packed maxes out at 16 Hz frame rate. From testing with SpinView, I can see that if I use the BayerRG8 pixel format for the camera I can reach the expected maximum framerate of 41 Hz and get color images. However, when I try to set the BayerRG8 pixel format in the EPICS control I get the following error in the IOC:
2025/08/14 10:18:30.364 ADSpinnaker:grabImage: unsupported pixel format=0x4
And the acquisition does not collect images.
Anyone know what’s going on here?
As a note, I did try regenerating the camera xml, template and display screens using aravis and the python scripts but have the same issue. This is aravis 0.8.35 on Debian 12.
I’ve included the entire IOC startup output below, and attached a screenshot of the main MEDM window. This is using EPICS base 7.0.8. AreaDetector, ADCore, ADSupport, ADGenICam, and ADSpinnaker (along with a few other AD modules) are all freshly downloaded from their respective github repos last week, using the latest version in the master branch. The IOC is being built and run on Debian 12.
All the best.
- Jesse
Entire IOC startup:
(main) biocat@dalek:/opt/epics/epics_iocs/soft_iocs/flir_cameras/iocBoot/iocflir_cameras$ ./st.cmd
#!../../bin/linux-x86_64/flir_cameras
< envPaths
epicsEnvSet("IOC","iocflir_cameras")
epicsEnvSet("TOP","/opt/epics/epics_iocs/soft_iocs/flir_cameras")
epicsEnvSet("SUPPORT","/opt/epics/synApps_6_3/support")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("ALIVE","/opt/epics/synApps_6_3/support/alive-R1-4-1")
epicsEnvSet("AREA_DETECTOR","/opt/epics/synApps_6_3/support/areaDetector-master")
epicsEnvSet("ASYN","/opt/epics/synApps_6_3/support/asyn-R4-44-2")
epicsEnvSet("AUTOSAVE","/opt/epics/synApps_6_3/support/autosave-R5-11")
epicsEnvSet("BUSY","/opt/epics/synApps_6_3/support/busy-R1-7-4")
epicsEnvSet("CALC","/opt/epics/synApps_6_3/support/calc-R3-7-5")
epicsEnvSet("CAMAC","/opt/epics/synApps_6_3/support/camac-R2-7-5")
epicsEnvSet("CAPUTRECORDER","/opt/epics/synApps_6_3/support/caputRecorder-R1-7-6")
epicsEnvSet("DAC128V","/opt/epics/synApps_6_3/support/dac128V-R2-10-1")
epicsEnvSet("DELAYGEN","/opt/epics/synApps_6_3/support/delaygen-R1-2-4")
epicsEnvSet("DEVIOCSTATS","/opt/epics/synApps_6_3/support/iocStats-3-1-16")
epicsEnvSet("ETHERIP","/opt/epics/synApps_6_3/support/ether_ip-ether_ip-3-3")
epicsEnvSet("GALIL","/opt/epics/synApps_6_3/support/Galil-4-0-02")
epicsEnvSet("IP","/opt/epics/synApps_6_3/support/ip-R2-22")
epicsEnvSet("IP330","/opt/epics/synApps_6_3/support/ip330-R2-10")
epicsEnvSet("IPAC","/opt/epics/synApps_6_3/support/ipac-2-16")
epicsEnvSet("IPUNIDIG","/opt/epics/synApps_6_3/support/ipUnidig-R2-12")
epicsEnvSet("LABJACK","/opt/epics/synApps_6_3/support/LabJack-master")
epicsEnvSet("LOVE","/opt/epics/synApps_6_3/support/love-R3-2-9")
epicsEnvSet("LUA","/opt/epics/synApps_6_3/support/lua-R3-1")
epicsEnvSet("MCA","/opt/epics/synApps_6_3/support/mca-R7-10")
epicsEnvSet("MEASCOMP","/opt/epics/synApps_6_3/support/measComp-master")
epicsEnvSet("MODBUS","/opt/epics/synApps_6_3/support/modbus-R3-3")
epicsEnvSet("MOTOR","/opt/epics/synApps_6_3/support/motor-R7-3-1")
epicsEnvSet("OPTICS","/opt/epics/synApps_6_3/support/optics-R2-14")
epicsEnvSet("SCALER","/opt/epics/synApps_6_3/support/scaler-4-1")
epicsEnvSet("SNCSEQ","/opt/epics/synApps_6_3/support/sequencer-mirror-R2-2-9")
epicsEnvSet("SOFTGLUE","/opt/epics/synApps_6_3/support/softGlue-R2-8-4")
epicsEnvSet("SOFTGLUEZYNQ","/opt/epics/synApps_6_3/support/softGlueZynq-R2-0-5")
epicsEnvSet("SSCAN","/opt/epics/synApps_6_3/support/sscan-R2-11-6")
epicsEnvSet("STD","/opt/epics/synApps_6_3/support/std-R3-6-4")
epicsEnvSet("STREAM","/opt/epics/synApps_6_3/support/StreamDevice-2-8-24")
epicsEnvSet("VAC","/opt/epics/synApps_6_3/support/vac-R1-9-2")
epicsEnvSet("VME","/opt/epics/synApps_6_3/support/vme-R2-9-5")
epicsEnvSet("XXX","/opt/epics/synApps_6_3/support/xxx-R6-3")
epicsEnvSet("YOKOGAWA_DAS","/opt/epics/synApps_6_3/support/Yokogawa_DAS-R2-0-2")
epicsEnvSet("ALLENBRADLEY","/opt/epics/synApps_6_3/support/allenBradley-2-3")
epicsEnvSet("ADCORE","/opt/epics/synApps_6_3/support/areaDetector-master/ADCore")
epicsEnvSet("ADSUPPORT","/opt/epics/synApps_6_3/support/areaDetector-master/ADSupport")
epicsEnvSet("ULDAQ","/opt/epics/synApps_6_3/support/measComp-R4-2/libuldaq-1.2.1")
epicsEnvSet("ADEIGER","/opt/epics/synApps_6_3/support/areaDetector-master/ADEiger")
epicsEnvSet("ADGENICAM","/opt/epics/synApps_6_3/support/areaDetector-master/ADGenICam")
epicsEnvSet("ADPILATUS","/opt/epics/synApps_6_3/support/areaDetector-master/ADPilatus")
epicsEnvSet("ADSPINNAKER","/opt/epics/synApps_6_3/support/areaDetector-master/ADSpinnaker")
epicsEnvSet("ADURL","/opt/epics/synApps_6_3/support/areaDetector-master/ADURL")
epicsEnvSet("ADMARCCD","/opt/epics/synApps_6_3/support/areaDetector-master/ADmarCCD")
epicsEnvSet("FFMPEGSERVER","/opt/epics/synApps_6_3/support/areaDetector-master/ffmpegServer")
errlogInit(20000)
dbLoadDatabase("/opt/epics/epics_iocs/soft_iocs/flir_cameras/dbd/flir_cameras.dbd")
flir_cameras_registerRecordDeviceDriver(pdbbase)
# Use this line for a specific camera by serial number, in this case a FLIR GigE
epicsEnvSet("CAMERA_ID", "24391576")
#epicsEnvSet("CAMERA_ID", "0")
epicsEnvSet("GENICAM_DB_FILE", "/opt/epics/synApps_6_3/support/areaDetector-master/ADGenICam/db/FLIR-BFS-PGE-23S6C.template")
< st.cmd.base
# Prefix for all records
epicsEnvSet("PREFIX", "18ID:FLIR:")
# The port name for the detector
epicsEnvSet("PORT",   "SP1")
# Really large queue so we can stream to disk at full camera speed
epicsEnvSet("QSIZE",  "2000")
# The maximim image width; used for row profiles in the NDPluginStats plugin
epicsEnvSet("XSIZE",  "1920")
# The maximim image height; used for column profiles in the NDPluginStats plugin
epicsEnvSet("YSIZE",  "1080")
# The maximum number of time series points in the NDPluginStats plugin
epicsEnvSet("NCHANS", "2048")
# The maximum number of frames buffered in the NDPluginCircularBuff plugin
epicsEnvSet("CBUFFS", "500")
# The search path for database files
# This is for Windows
#epicsEnvSet("EPICS_DB_INCLUDE_PATH", "$(ADCORE)/db;$(ADGENICAM)/db;$(ADSPINNAKER)/db")
# This is for Linux
epicsEnvSet("EPICS_DB_INCLUDE_PATH", "/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db:/opt/epics/synApps_6_3/support/areaDetector-master/ADGenICam/db:/opt/epics/synApps_6_3/support/areaDetector-master/ADSpinnaker/db")
# Define NELEMENTS to be enough for a 1920*1080*3 (color) image
epicsEnvSet("NELEMENTS", "6220800")
# ADSpinnakerConfig(const char *portName, const char *cameraId, int numSPBuffers,
#                   size_t maxMemory, int priority, int stackSize)
ADSpinnakerConfig("SP1", 24391576)
asynSetTraceIOMask(SP1, 0, 2)
# Set ASYN_TRACE_WARNING and ASYN_TRACE_ERROR
#asynSetTraceMask($(PORT), 0, 0xff)
#asynSetTraceFile($(PORT), 0, "asynTrace.out")
#asynSetTraceInfoMask($(PORT), 0, 0xf)
# Main database.  This just loads and modifies ADBase.template
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADSpinnaker/db/spinnaker.template", "P=18ID:FLIR:,R=cam1:,PORT=SP1")
# Load the autogenerated file of GenICam features
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADGenICam/db/FLIR-BFS-PGE-23S6C.template", "P=18ID:FLIR:,R=cam1:,PORT=SP1")
# Transport diagnostics
#dbLoadRecords("$(ADSPINNAKER)/db/spinnakerIntReadback.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),PROP=TransmitFailureCount,PN=SP_TRANSMIT_FAILURE_COUNT")
#dbLoadRecords("$(ADSPINNAKER)/db/spinnakerIntReadback.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),PROP=BufferUnderrunCount, PN=SP_BUFFER_UNDERRUN_COUNT")
#dbLoadRecords("$(ADSPINNAKER)/db/spinnakerIntReadback.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),PROP=FailedBufferCount,   PN=SP_FAILED_BUFFER_COUNT")
#dbLoadRecords("$(ADSPINNAKER)/db/spinnakerIntReadback.template", "P=$(PREFIX),R=cam1:,PORT=$(PORT),PROP=FailedPacketCount,   PN=SP_FAILED_PACKET_COUNT")
# Create a standard arrays plugin
NDStdArraysConfigure("Image1", 5, 0, "SP1", 0, 0)
# Use this line for 8-bit data only
#dbLoadRecords("$(ADCORE)/db/NDStdArrays.template", "P=$(PREFIX),R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT),TYPE=Int8,FTVL=CHAR,NELEMENTS=$(NELEMENTS)")
# Use this line for 8-bit or 16-bit data
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db/NDStdArrays.template", "P=18ID:FLIR:,R=image1:,PORT=Image1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1,TYPE=Int16,FTVL=SHORT,NELEMENTS=6220800")
# Load all other plugins using commonPlugins.cmd
< /opt/epics/synApps_6_3/support/areaDetector-master/ADCore/iocBoot/commonPlugins.cmd
# This is an example file for creating plugins
# It uses the following environment variable macros
# Many of the parameters defined in this file are also in commonPlugins_settings.req so if autosave is being
# use the autosave value will replace the value passed to this file.
# $(PREFIX)      Prefix for all records
# $(PORT)        The port name for the detector.  In autosave.
# $(QSIZE)       The queue size for all plugins.  In autosave.
# $(XSIZE)       The maximum image width; used to set the maximum size for row profiles in the NDPluginStats plugin and 1-D FFT
#                   profiles in NDPluginFFT.
# $(YSIZE)       The maximum image height; used to set the maximum size for column profiles in the NDPluginStats plugin
# $(NCHANS)      The maximum number of time series points in the NDPluginStats, NDPluginROIStats, and NDPluginAttribute plugins
# $(CBUFFS)      The maximum number of frames buffered in the NDPluginCircularBuff plugin
# $(MAX_THREADS) The maximum number of threads for plugins which can run in multiple threads. Defaults to 5.
# Create a netCDF file saving plugin
NDFileNetCDFConfigure("FileNetCDF1", 2000, 0, "SP1", 0)
dbLoadRecords("NDFileNetCDF.template","P=18ID:FLIR:,R=netCDF1:,PORT=FileNetCDF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create a TIFF file saving plugin
NDFileTIFFConfigure("FileTIFF1", 2000, 0, "SP1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=18ID:FLIR:,R=TIFF1:,PORT=FileTIFF1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create a JPEG file saving plugin
NDFileJPEGConfigure("FileJPEG1", 2000, 0, "SP1", 0)
dbLoadRecords("NDFileJPEG.template",  "P=18ID:FLIR:,R=JPEG1:,PORT=FileJPEG1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create a NeXus file saving plugin
NDFileNexusConfigure("FileNexus1", 2000, 0, "SP1", 0)
dbLoadRecords("NDFileNexus.template", "P=18ID:FLIR:,R=Nexus1:,PORT=FileNexus1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create an HDF5 file saving plugin
NDFileHDF5Configure("FileHDF1", 2000, 0, "SP1", 0)
dbLoadRecords("NDFileHDF5.template",  "P=18ID:FLIR:,R=HDF1:,PORT=FileHDF1,ADDR=0,TIMEOUT=1,XMLSIZE=2048,NDARRAY_PORT=SP1")
# Create a Magick file saving plugin
#NDFileMagickConfigure("FileMagick1", $(QSIZE), 0, "$(PORT)", 0)
#dbLoadRecords("NDFileMagick.template","P=$(PREFIX),R=Magick1:,PORT=FileMagick1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
# Create 4 ROI plugins
NDROIConfigure("ROI1", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=18ID:FLIR:,R=ROI1:,  PORT=ROI1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
NDROIConfigure("ROI2", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=18ID:FLIR:,R=ROI2:,  PORT=ROI2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
NDROIConfigure("ROI3", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=18ID:FLIR:,R=ROI3:,  PORT=ROI3,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
NDROIConfigure("ROI4", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDROI.template",       "P=18ID:FLIR:,R=ROI4:,  PORT=ROI4,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create 8 ROIStat plugins
NDROIStatConfigure("ROISTAT1", 2000, 0, "SP1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDROIStat.template",   "P=18ID:FLIR:,R=ROIStat1:  ,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=18ID:FLIR:,R=ROIStat1:1:,PORT=ROISTAT1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=18ID:FLIR:,R=ROIStat1:2:,PORT=ROISTAT1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=18ID:FLIR:,R=ROIStat1:3:,PORT=ROISTAT1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=18ID:FLIR:,R=ROIStat1:4:,PORT=ROISTAT1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=18ID:FLIR:,R=ROIStat1:5:,PORT=ROISTAT1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=18ID:FLIR:,R=ROIStat1:6:,PORT=ROISTAT1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=18ID:FLIR:,R=ROIStat1:7:,PORT=ROISTAT1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDROIStatN.template",  "P=18ID:FLIR:,R=ROIStat1:8:,PORT=ROISTAT1,ADDR=7,TIMEOUT=1,NCHANS=2048")
# Create a processing plugin
NDProcessConfigure("PROC1", 2000, 0, "SP1", 0, 0, 0)
dbLoadRecords("NDProcess.template",   "P=18ID:FLIR:,R=Proc1:,  PORT=PROC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create a TIFF file plugin to read dark and flatfield images into the processing plugin
NDFileTIFFConfigure("PROC1TIFF", 2000, 0, "SP1", 0)
dbLoadRecords("NDFileTIFF.template",  "P=18ID:FLIR:,R=Proc1:TIFF:,PORT=PROC1TIFF,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create a scatter plugin
NDScatterConfigure("SCATTER1", 2000, 0, "SP1", 0, 0, 0)
dbLoadRecords("NDScatter.template",   "P=18ID:FLIR:,R=Scatter1:,  PORT=SCATTER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create a gather plugin with 8 ports
NDGatherConfigure("GATHER1", 2000, 0, 8, 0, 0)
dbLoadRecords("NDGather.template",   "P=18ID:FLIR:,R=Gather1:, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDGatherN.template",   "P=18ID:FLIR:,R=Gather1:, N=1, PORT=GATHER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDGatherN.template",   "P=18ID:FLIR:,R=Gather1:, N=2, PORT=GATHER1,ADDR=1,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDGatherN.template",   "P=18ID:FLIR:,R=Gather1:, N=3, PORT=GATHER1,ADDR=2,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDGatherN.template",   "P=18ID:FLIR:,R=Gather1:, N=4, PORT=GATHER1,ADDR=3,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDGatherN.template",   "P=18ID:FLIR:,R=Gather1:, N=5, PORT=GATHER1,ADDR=4,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDGatherN.template",   "P=18ID:FLIR:,R=Gather1:, N=6, PORT=GATHER1,ADDR=5,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDGatherN.template",   "P=18ID:FLIR:,R=Gather1:, N=7, PORT=GATHER1,ADDR=6,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDGatherN.template",   "P=18ID:FLIR:,R=Gather1:, N=8, PORT=GATHER1,ADDR=7,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create 5 statistics plugins
NDStatsConfigure("STATS1", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=18ID:FLIR:,R=Stats1:,  PORT=STATS1,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1920,YSIZE=1080,NCHANS=2048,NDARRAY_PORT=SP1")
NDTimeSeriesConfigure("STATS1_TS", 2000, 0, "STATS1", 1, 23)
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db/NDTimeSeries.template",  "P=18ID:FLIR:,R=Stats1:TS:, PORT=STATS1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS2", 2000, 0, "ROI1",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=18ID:FLIR:,R=Stats2:,  PORT=STATS2,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1920,YSIZE=1080,NCHANS=2048,NDARRAY_PORT=SP1")
NDTimeSeriesConfigure("STATS2_TS", 2000, 0, "STATS2", 1, 23)
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db/NDTimeSeries.template",  "P=18ID:FLIR:,R=Stats2:TS:, PORT=STATS2_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS2,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS3", 2000, 0, "ROI2",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=18ID:FLIR:,R=Stats3:,  PORT=STATS3,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1920,YSIZE=1080,NCHANS=2048,NDARRAY_PORT=SP1")
NDTimeSeriesConfigure("STATS3_TS", 2000, 0, "STATS3", 1, 23)
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db/NDTimeSeries.template",  "P=18ID:FLIR:,R=Stats3:TS:, PORT=STATS3_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS3,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS4", 2000, 0, "ROI3",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=18ID:FLIR:,R=Stats4:,  PORT=STATS4,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1920,YSIZE=1080,NCHANS=2048,NDARRAY_PORT=SP1")
NDTimeSeriesConfigure("STATS4_TS", 2000, 0, "STATS4", 1, 23)
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db/NDTimeSeries.template",  "P=18ID:FLIR:,R=Stats4:TS:, PORT=STATS4_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS4,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
NDStatsConfigure("STATS5", 2000, 0, "ROI4",    0, 0, 0, 0, 0, 5)
dbLoadRecords("NDStats.template",     "P=18ID:FLIR:,R=Stats5:,  PORT=STATS5,ADDR=0,TIMEOUT=1,HIST_SIZE=256,XSIZE=1920,YSIZE=1080,NCHANS=2048,NDARRAY_PORT=SP1")
NDTimeSeriesConfigure("STATS5_TS", 2000, 0, "STATS5", 1, 23)
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db/NDTimeSeries.template",  "P=18ID:FLIR:,R=Stats5:TS:, PORT=STATS5_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=STATS5,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create a transform plugin
NDTransformConfigure("TRANS1", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDTransform.template", "P=18ID:FLIR:,R=Trans1:,  PORT=TRANS1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create an overlay plugin with 8 overlays
NDOverlayConfigure("OVER1", 2000, 0, "SP1", 0, 8, 0, 0, 0, 0, 5)
dbLoadRecords("NDOverlay.template", "P=18ID:FLIR:,R=Over1:, PORT=OVER1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
dbLoadRecords("NDOverlayN.template","P=18ID:FLIR:,R=Over1:1:,NAME=ROI1,   SHAPE=1,O=Over1:,XPOS=18ID:FLIR:ROI1:MinX_RBV,YPOS=18ID:FLIR:ROI1:MinY_RBV,XSIZE=18ID:FLIR:ROI1:SizeX_RBV,YSIZE=18ID:FLIR:ROI1:SizeY_RBV,PORT=OVER1,ADDR=0,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=18ID:FLIR:,R=Over1:2:,NAME=ROI2,   SHAPE=1,O=Over1:,XPOS=18ID:FLIR:ROI2:MinX_RBV,YPOS=18ID:FLIR:ROI2:MinY_RBV,XSIZE=18ID:FLIR:ROI2:SizeX_RBV,YSIZE=18ID:FLIR:ROI2:SizeY_RBV,PORT=OVER1,ADDR=1,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=18ID:FLIR:,R=Over1:3:,NAME=ROI3,   SHAPE=1,O=Over1:,XPOS=18ID:FLIR:ROI3:MinX_RBV,YPOS=18ID:FLIR:ROI3:MinY_RBV,XSIZE=18ID:FLIR:ROI3:SizeX_RBV,YSIZE=18ID:FLIR:ROI3:SizeY_RBV,PORT=OVER1,ADDR=2,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=18ID:FLIR:,R=Over1:4:,NAME=ROI4,   SHAPE=1,O=Over1:,XPOS=18ID:FLIR:ROI4:MinX_RBV,YPOS=18ID:FLIR:ROI4:MinY_RBV,XSIZE=18ID:FLIR:ROI4:SizeX_RBV,YSIZE=18ID:FLIR:ROI4:SizeY_RBV,PORT=OVER1,ADDR=3,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=18ID:FLIR:,R=Over1:5:,NAME=Cursor1,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=4,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=18ID:FLIR:,R=Over1:6:,NAME=Cursor2,SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=5,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=18ID:FLIR:,R=Over1:7:,NAME=Box1,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=6,TIMEOUT=1")
dbLoadRecords("NDOverlayN.template","P=18ID:FLIR:,R=Over1:8:,NAME=Box2,   SHAPE=1,O=Over1:,XPOS=junk,                  YPOS=junk,                  XSIZE=junk,                   YSIZE=junk,                   PORT=OVER1,ADDR=7,TIMEOUT=1")
# Create 2 color conversion plugins
NDColorConvertConfigure("CC1", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=18ID:FLIR:,R=CC1:,  PORT=CC1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
NDColorConvertConfigure("CC2", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDColorConvert.template", "P=18ID:FLIR:,R=CC2:,  PORT=CC2,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create a circular buffer plugin
NDCircularBuffConfigure("CB1", 2000, 0, "SP1", 0, 500, 0)
dbLoadRecords("NDCircularBuff.template", "P=18ID:FLIR:,R=CB1:,  PORT=CB1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
# Create an NDAttribute plugin with 8 attributes
NDAttrConfigure("ATTR1", 2000, 0, "SP1", 0, 8, 0, 0, 0)
dbLoadRecords("NDAttribute.template",  "P=18ID:FLIR:,R=Attr1:,    PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048,NDARRAY_PORT=SP1")
dbLoadRecords("NDAttributeN.template", "P=18ID:FLIR:,R=Attr1:1:,  PORT=ATTR1,ADDR=0,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=18ID:FLIR:,R=Attr1:2:,  PORT=ATTR1,ADDR=1,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=18ID:FLIR:,R=Attr1:3:,  PORT=ATTR1,ADDR=2,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=18ID:FLIR:,R=Attr1:4:,  PORT=ATTR1,ADDR=3,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=18ID:FLIR:,R=Attr1:5:,  PORT=ATTR1,ADDR=4,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=18ID:FLIR:,R=Attr1:6:,  PORT=ATTR1,ADDR=5,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=18ID:FLIR:,R=Attr1:7:,  PORT=ATTR1,ADDR=6,TIMEOUT=1,NCHANS=2048")
dbLoadRecords("NDAttributeN.template", "P=18ID:FLIR:,R=Attr1:8:,  PORT=ATTR1,ADDR=7,TIMEOUT=1,NCHANS=2048")
NDTimeSeriesConfigure("ATTR1_TS", 2000, 0, "ATTR1", 1, 8)
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db/NDTimeSeries.template",  "P=18ID:FLIR:,R=Attr1:TS:, PORT=ATTR1_TS,ADDR=0,TIMEOUT=1,NDARRAY_PORT=ATTR1,NDARRAY_ADDR=1,NCHANS=2048,ENABLED=1")
# Create an FFT plugin
NDFFTConfigure("FFT1", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDFFT.template", "P=18ID:FLIR:, R=FFT1:, PORT=FFT1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=SP1, NAME=FFT1, NCHANS=1920")
# Create 2 Codec plugins
NDCodecConfigure("CODEC1", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDCodec.template", "P=18ID:FLIR:, R=Codec1:, PORT=CODEC1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=SP1")
NDCodecConfigure("CODEC2", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDCodec.template", "P=18ID:FLIR:, R=Codec2:, PORT=CODEC2, ADDR=0, TIMEOUT=1, NDARRAY_PORT=SP1")
# Create a bad pixel plugin
NDBadPixelConfigure("BADPIX1", 2000, 0, "SP1", 0, 0, 0, 0, 0, 5)
dbLoadRecords("NDBadPixel.template", "P=18ID:FLIR:, R=BadPix1:, PORT=BADPIX1, ADDR=0, TIMEOUT=1, NDARRAY_PORT=SP1")
# Load NDPluginPva plugin
NDPvaConfigure("PVA1", 2000, 0, "SP1", 0, 18ID:FLIR:Pva1:Image, 0, 0, 0)
dbLoadRecords("NDPva.template",  "P=18ID:FLIR:,R=Pva1:, PORT=PVA1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=SP1")
#Must start PVA server if this is enabled
startPVAServer
2025-08-14T10:17:39.586 Using dynamically assigned TCP port 59963.
set_requestfile_path("./")
set_requestfile_path("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/db")
set_requestfile_path("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/iocBoot")
set_requestfile_path("/opt/epics/synApps_6_3/support/autosave-R5-11/db")
set_requestfile_path("/opt/epics/synApps_6_3/support/calc-R3-7-5/db")
set_savefile_path("./autosave")
set_pass0_restoreFile("auto_settings.sav")
set_pass1_restoreFile("auto_settings.sav")
save_restoreSet_status_prefix("18ID:FLIR:")
dbLoadRecords("/opt/epics/synApps_6_3/support/autosave-R5-11/db/save_restoreStatus.db", "P=18ID:FLIR:")
dbLoadRecords("/opt/epics/synApps_6_3/support/autosave-R5-11/db/configMenu.db", "P=18ID:FLIR:, CONFIG=ADAutoSave")
# Optional: load ffmpegServer plugin
#ffmpegServerConfigure(8081)
#ffmpegStreamConfigure("FfmStream1", 2, 0, "$(PORT)", 0, -1, 0)
#dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegStream.template", "P=$(PREFIX),R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=$(PORT)")
#ffmpegFileConfigure("FfmFile1", 16, 0, "$(PORT)", 0, -1, 0)
#dbLoadRecords("$(FFMPEGSERVER)/db/ffmpegFile.template", "P=$(PREFIX),R=ffmfile1:,PORT=FfmFile1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(FFMPEGSERVER)/db")
# Optional: load NDPluginEdge plugin
#NDEdgeConfigure("EDGE1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0)
#dbLoadRecords("$(ADPLUGINEDGE)/db/NDEdge.template",  "P=$(PREFIX),R=Edge1:, PORT=EDGE1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINEDGE)/db")
# Optional: load NDPluginCV plugin
#NDCVConfigure("CV1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
#dbLoadRecords("$(ADCOMPVISION)/db/NDCV.template",  "P=$(PREFIX),R=CV1:, PORT=CV1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADCOMPVISION)/db")
# Optional: load NDPluginBar plugin
#NDBarConfigure("BAR1", $(QSIZE), 0, "$(PORT)", 0, 0, 0, 0, 0, $(MAX_THREADS=5))
#dbLoadRecords("$(ADPLUGINBAR)/db/NDBar.template",  "P=$(PREFIX),R=Bar1:, PORT=BAR1,ADDR=0,TIMEOUT=1,NDARRAY_PORT=$(PORT)")
#set_requestfile_path("$(ADPLUGINBAR)/db")
# Optional: load scan records
#dbLoadRecords("$(SSCAN)/db/scan.db", "P=$(PREFIX),MAXPTS1=2000,MAXPTS2=200,MAXPTS3=20,MAXPTS4=10,MAXPTSH=10")
#set_requestfile_path("$(SSCAN)/db")
# Optional: load sseq record for acquisition sequence
#dbLoadRecords("$(CALC)/db/sseqRecord.db", "P=$(PREFIX), S=AcquireSequence")
#set_requestfile_path("$(CALC)/db")
# Optional: load devIocStats records (requires DEVIOCSTATS module)
#dbLoadRecords("$(DEVIOCSTATS)/db/iocAdminSoft.db", "IOC=$(PREFIX)")
# Optional: load alive record (requires ALIVE module)
#dbLoadRecords("$(ALIVE)/db/alive.db", "P=$(PREFIX),RHOST=192.168.1.254")
# Set the callback queue size to 5000, up from default of 2000 in base.
# This can be needed to avoid errors "callbackRequest: cbLow ring buffer full".
callbackSetQueueSize(5000)
set_requestfile_path("/opt/epics/synApps_6_3/support/areaDetector-master/ADGenICam/GenICamApp/Db")
set_requestfile_path("/opt/epics/synApps_6_3/support/areaDetector-master/ADSpinnaker/spinnakerApp/Db")
set_requestfile_path("/opt/epics/synApps_6_3/support/areaDetector-master/ADCore/ADApp/Db")
Starting server on port 8081...
Null httpd 0.5.1
Binding to 'http://any:8081/'...OK.
OK
ffmpegStreamConfigure("FfmStream1", 2, 0, "SP1", 0, -1, 0)
dbLoadRecords("/opt/epics/synApps_6_3/support/areaDetector-master/ffmpegServer/db/ffmpegStream.template", "P=18ID:FLIR:,R=ffmstream1:,PORT=FfmStream1,NDARRAY_PORT=SP1")
set_requestfile_path("/opt/epics/synApps_6_3/support/areaDetector-master/ffmpegServer/db")
iocInit()
Starting iocInit
## EPICS R7.0.8
## Rev. 2024-03-01T16:24-0600
## Rev. Date build date/time:
drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set.
7 PVs had no saved value.
cas WARNING: Configured TCP port was unavailable.
cas WARNING: Using dynamically assigned TCP port 43937,
cas WARNING: but now two or more servers share the same UDP port.
cas WARNING: Depending on your IP kernel this server may not be
cas WARNING: reachable with UDP unicast (a host's IP in EPICS_CA_ADDR_LIST)
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30,"P=18ID:FLIR:")
# Wait for enum callbacks to complete
epicsThreadSleep(1.0)
# Wait for callbacks on the property limits (DRVL, DRVH) to complete
save_restore: connect failed for channel '18ID:FLIR:cam1:GC_BlackLevelAuto'
save_restore: connect failed for channel '18ID:FLIR:cam1:GC_SaturationEnabled'
save_restore: connect failed for channel '18ID:FLIR:cam1:GC_GammaEnabled'
save_restore: connect failed for channel '18ID:FLIR:cam1:GC_Sharpness'
save_restore: connect failed for channel '18ID:FLIR:cam1:GC_SharpnessAuto'
save_restore: connect failed for channel '18ID:FLIR:cam1:GC_SharpnessEnabled'
save_restore: connect failed for channel '18ID:FLIR:cam1:GC_TriDelayEnabled'
auto_settings.sav: 2391 of 2398 PV's connected
Jesse Hopkins, PhD (he/him)
Director, BioCAT
Sector 18, Advanced Photon Source
Research Associate Professor, Illinois Tech
<Screenshot 2025-08-14 at 10.25.16 AM.png>
Can't use BayerRG8 pixel format with ADSpinnaker Jesse Hopkins via Tech-talk
Prev: Re: Can't use BayerRG8 pixel format with ADSpinnaker Mark Rivers via Tech-talk
Next: Re: [Ext]Re: Can't use BayerRG8 pixel format with ADSpinnaker Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
