HI,
after some research I found the problem. The libraries in the e3-adaravis wrapper Makefile are added to the
USR_LDFLAGS variable, which results in a wrong ordering of the variables on the commandline for the linker.
The glibb, usb and aravis libraries are placed before the objects of ADAravis. So the linker does not search them for the
missing symbols.
If one adds the libraries to USR_LIBS, the problem seems to be solved. Note one can not use the pkg-config command here,
as EPICS adds "-l" to each component of the USR_LIBS string.
By the way, has this effect been observed before?
Jörn
Am Montag, 18. August 2025, 14:42:43 Mitteleuropäische Sommerzeit schrieb Jörn Dreyer via Tech-talk:
> Hi,
> some time ago I build EPICS using E3 on my OpenSuSE Tumbleweed system when it still used GCC 14. As time progresses gcc 15 became the default compiler on Tubleweed.
> Unfortunately this one fails to build EPICS currently. So I decided to move my development into an container using Debian 13 as the OS using gcc 14.2.
> I got the complete EPICS installed together with the ADCore, ADGenICam and ADAravis modules that I need to read some Basler cameras.
> But when I started my IOC script if fails during loading of the libADAravis with an undefined symbol error (g_direct_hash). This should be defined in libglib.so.
> So I took a closer look at the library using ldd:
> Building libADArvis.so using e3-build-tools results in:
> e3-adaravis/ADAravis/O.7.0.8.1_linux-x86_64$ ldd libadaravis.so
> linux-vdso.so.1 (0x00007f5eedba8000)
> libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f5eed800000)
> libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f5eed710000)
> libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f5eedaa8000)
> libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f5eed51a000)
> /lib64/ld-linux-x86-64.so.2 (0x00007f5eedbaa000)
> And compared that to the library I build on my Tumbleweed system using E3:
> adaravis/2.3.0+2/lib/linux-x86_64 $ldd libadaravis.so
> linux-vdso.so.1 (0x00007f41e1c85000)
> libgio-2.0.so.0 => /lib64/libgio-2.0.so.0 (0x00007f41e199d000)
> libgobject-2.0.so.0 => /lib64/libgobject-2.0.so.0 (0x00007f41e193b000)
> libglib-2.0.so.0 => /lib64/libglib-2.0.so.0 (0x00007f41e17e4000)
> libusb-1.0.so.0 => /lib64/libusb-1.0.so.0 (0x00007f41e17c2000)
> libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007f41e1400000)
> libm.so.6 => /lib64/libm.so.6 (0x00007f41e16cd000)
> libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007f41e16a0000)
> libc.so.6 => /lib64/libc.so.6 (0x00007f41e1000000)
> libgmodule-2.0.so.0 => /lib64/libgmodule-2.0.so.0 (0x00007f41e1699000)
> libz.so.1 => /lib64/glibc-hwcaps/x86-64-v3/libz.so.1.3.1 (0x00007f41e167d000)
> libmount.so.1 => /lib64/libmount.so.1 (0x00007f41e13a9000)
> libselinux.so.1 => /lib64/libselinux.so.1 (0x00007f41e1377000)
> libffi.so.8 => /lib64/libffi.so.8 (0x00007f41e1672000)
> libpcre2-8.so.0 => /lib64/libpcre2-8.so.0 (0x00007f41e12bb000)
> libudev.so.1 => /lib64/libudev.so.1 (0x00007f41e1276000)
> /lib64/ld-linux-x86-64.so.2 (0x00007f41e1c87000)
> libblkid.so.1 => /lib64/libblkid.so.1 (0x00007f41e1239000)
> libcap.so.2 => /lib64/libcap.so.2 (0x00007f41e122d000)
> libeconf.so.0 => /lib64/libeconf.so.0 (0x00007f41e121f000)
> For a crosscheck, I compiled the same under Ubuntu 22.04 using gcc 11.4:
> Using e3 resulted in:
> adaravis/2.3.0+2/lib/linux-x86_64$ ldd libadaravis.so
> linux-vdso.so.1 (0x00007ffe18474000)
> libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f32bf652000)
> libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f32bf56b000)
> libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f32bf54b000)
> libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f32bf322000)
> /lib64/ld-linux-x86-64.so.2 (0x00007f32bf955000)
> And for the EPICS build system:
> ADAravis/lib/linux-x86_64$ ldd libADAravis.so
> linux-vdso.so.1 (0x00007ffca4d91000)
> libADGenICam.so => /XXX/modules/src/areaDetector/ADGenICam/lib/linux-x86_64/libADGenICam.so (0x00007fd29dc5a000)
> libaravis-0.8.so.0 => /lib/x86_64-linux-gnu/libaravis-0.8.so.0 (0x00007fd29dbba000)
> libgobject-2.0.so.0 => /lib/x86_64-linux-gnu/libgobject-2.0.so.0 (0x00007fd29db5a000)
> libglib-2.0.so.0 => /lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007fd29da20000)
> libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fd29d7f4000)
> libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fd29d7d2000)
> libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fd29d5a9000)
> libADBase.so => /XXX/modules/src/areaDetector/ADCore/lib/linux-x86_64/libADBase.so (0x00007fd29d56e000)
> libasyn.so => /XXX/modules/src/asyn/lib/linux-x86_64/libasyn.so (0x00007fd29d4c7000)
> libnanohttp_stream.so => /XXX/modules/src/areaDetector/ADSupport/lib/linux-x86_64/libnanohttp_stream.so (0x00007fd29d33d000)
> libCom.so.3.18.0 => /XXX/base-7.0.4/lib/linux-x86_64/libCom.so.3.18.0 (0x00007fd29d2c0000)
> libgio-2.0.so.0 => /lib/x86_64-linux-gnu/libgio-2.0.so.0 (0x00007fd29d0e6000)
> libxml2.so.2 => /lib/x86_64-linux-gnu/libxml2.so.2 (0x00007fd29cf04000)
> libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fd29cee8000)
> libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fd29ce01000)
> libusb-1.0.so.0 => /lib/x86_64-linux-gnu/libusb-1.0.so.0 (0x00007fd29cde1000)
> libffi.so.8 => /lib/x86_64-linux-gnu/libffi.so.8 (0x00007fd29cdd4000)
> libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007fd29cd5e000)
> /lib64/ld-linux-x86-64.so.2 (0x00007fd29dc84000)
> libdbCore.so.3.18.0 => /XXX/base-7.0.4/lib/linux-x86_64/libdbCore.so.3.18.0 (0x00007fd29ccc7000)
> libca.so.4.13.6 => /XXX/base-7.0.4/lib/linux-x86_64/libca.so.4.13.6 (0x00007fd29cc5d000)
> libxml2.so => /XXX/modules/src/areaDetector/ADSupport/lib/linux-x86_64/libxml2.so (0x00007fd29cad7000)
> libtirpc.so.3 => /lib/x86_64-linux-gnu/libtirpc.so.3 (0x00007fd29caa9000)
> libzlib.so => /XXX/modules/src/areaDetector/ADSupport/lib/linux-x86_64/libzlib.so (0x00007fd29ca8f000)
> libreadline.so.8 => /lib/x86_64-linux-gnu/libreadline.so.8 (0x00007fd29ca3b000)
> libgmodule-2.0.so.0 => /lib/x86_64-linux-gnu/libgmodule-2.0.so.0 (0x00007fd29ca34000)
> libmount.so.1 => /lib/x86_64-linux-gnu/libmount.so.1 (0x00007fd29c9ee000)
> libselinux.so.1 => /lib/x86_64-linux-gnu/libselinux.so.1 (0x00007fd29c9c2000)
> libicuuc.so.70 => /lib/x86_64-linux-gnu/libicuuc.so.70 (0x00007fd29c7c7000)
> liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5 (0x00007fd29c79c000)
> libudev.so.1 => /lib/x86_64-linux-gnu/libudev.so.1 (0x00007fd29c772000)
> libgssapi_krb5.so.2 => /lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007fd29c71c000)
> libtinfo.so.6 => /lib/x86_64-linux-gnu/libtinfo.so.6 (0x00007fd29c6ea000)
> libblkid.so.1 => /lib/x86_64-linux-gnu/libblkid.so.1 (0x00007fd29c6b3000)
> libpcre2-8.so.0 => /lib/x86_64-linux-gnu/libpcre2-8.so.0 (0x00007fd29c61c000)
> libicudata.so.70 => /lib/x86_64-linux-gnu/libicudata.so.70 (0x00007fd29a9fe000)
> libkrb5.so.3 => /lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007fd29a931000)
> libk5crypto.so.3 => /lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007fd29a902000)
> libcom_err.so.2 => /lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007fd29a8fc000)
> libkrb5support.so.0 => /lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007fd29a8ee000)
> libkeyutils.so.1 => /lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007fd29a8e7000)
> libresolv.so.2 => /lib/x86_64-linux-gnu/libresolv.so.2 (0x00007fd29a8d3000)
> I checked that e3 puts all the libraries (aravis, glib, gobject, gmodule, usb) on the commandline when linking the library.
> So to my surprise they are not referenced in the shared library under Debian when using e3 but when building with the EPICS build system.
> But why do they show up on Tumbleweed then?
> Any advice how to get that working is appreciated.
> Regards
> Jörn Dreyer
Dr. Jörn Dreyer
HIBEF DAQ + Controls
Institut für Strahlenpysik
Helmholtz-Zentrum Dresden - Rossendorf e.V. (HZDR)
Bautzner Landstr. 400 | 01328 Dresden | Germany
https://gcc02.safelinks.protection.outlook.com/?url="">
Vorstand: Prof. Dr. Sebastian M. Schmidt, Dr. Diana Stiller
Vereinsregister: VR 1693 beim Amtsgericht Dresden
