1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: synchronizing the value of a read/write record
From: "Thomas, Patrick via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected] Talk" <[email protected]>, "Thomas, Patrick" <[email protected]>
Date: Tue, 19 Aug 2025 17:21:50 +0000
Hello,
I'm working through implementing a class that inherits from asynPortDriver and attempting to override the 'connect' virtual method. However, the code I have overridden it with never appears to be called. Is there a configuration parameter or something else that I need to do to have this work?
Thank you,
Patrick
From: Tech-talk <[email protected]> on behalf of Thomas, Patrick via Tech-talk <[email protected]>
Sent: Wednesday, August 13, 2025 10:45 AM
To: Mark Rivers <[email protected]>; [email protected] Talk <[email protected]>
Hi Mark,
I did see that and was starting to look at using asyn, but I was having trouble figuring out how to do so. Is there a minimal working example that I might be able to modify? Do I need to create separate driver and device support?
The other thought I had was if this could be handled by somehow creating record support for read/write records.
Thank you,
Patrick
Sent: Wednesday, August 13, 2025 5:48 AM
To: [email protected] Talk <[email protected]>; Thomas, Patrick <[email protected]>
Hi Patrick,
As Ralph said, if your driver is written using asyn then you can use the info(asyn:READBACK) tag on your output record.
  • Is there any way to synchronize things so that write requests coming from channel access are always written to the hardware and not overridden by periodic updates from reading the hardware?
I'm not sure what you mean here.  I think the EPICS record locking an asyn port locking will guarantee that all EPICS writes get sent to the hardware atomically, and that all callbacks from the driver that update the output record will be atomic.  However, once EPICS writes the value to the hardware, the next poll of the hardware could quickly change the output record.  Maybe I am not understanding your question.
Sent: Tuesday, August 12, 2025 7:41 PM
Subject: synchronizing the value of a read/write record
Hello,
I'm attempting to write device support to handle the scenario where changes to the value of a hardware device can be made from both EPICS and another source. I would like the value of the hardware to be changed if I write a value to the record through channel access, and also to continuously monitor the hardware device for changes made from the other source and update the value of the record to match. One approach I have considered is to use separate output and input records, where the output records write values set from channel access to the hardware and the input records periodically scan the hardware and update their values accordingly. I am wondering however if there is a way to do this with the val field of just an output record. Is there any way to synchronize things so that write requests coming from channel access are always written to the hardware and not overridden by periodic updates from reading the hardware?
Thank you,
Patrick
Re: synchronizing the value of a read/write record Michael Davidsaver via Tech-talk
synchronizing the value of a read/write record Thomas, Patrick via Tech-talk
Re: synchronizing the value of a read/write record Mark Rivers via Tech-talk
Re: synchronizing the value of a read/write record Thomas, Patrick via Tech-talk
Prev: Re: Strange effect when building EPICS using e3-build-tools (formerly e3) Michael Davidsaver via Tech-talk
Next: Re: synchronizing the value of a read/write record Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: synchronizing the value of a read/write record Thomas, Patrick via Tech-talk
