1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Building EPICS base with Yocto
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Paduan Donadio, Marcio" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Thu, 28 Aug 2025 16:42:32 +0000
Hi Marcio,
I can’t help you specifically with Yocto or Bitbake, but for embedded IOC builds I would recommend turning off shared libraries for that target architecture and doing a static build of the IOC executable. You could even try whole-program-optimization if you know how.
That way you don’t have to worry about configuring shared library search paths since all the EPICS code will have been linked into the executable, and the IOC will probably start very slightly quicker as the OS doesn’t have to resolve all the internal symbols at load-time.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 8/28/25, 11:10 AM, "Tech-talk" <[email protected]> wrote:
Hello.
I’m familiar with the approach of building EPICS base in a host machine, selecting different architectures, and then configuring Yocto to access the EPICS libraries that are installed in the host. But was anyone able to build EPICS base using a Bitbake recipe inside Yocto?
Cheers,
Marcio
Re: Building EPICS base with Yocto Han Lee via Tech-talk
Building EPICS base with Yocto Paduan Donadio, Marcio via Tech-talk
Prev: Building EPICS base with Yocto Paduan Donadio, Marcio via Tech-talk
Next: Re: Building EPICS base with Yocto Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
