1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: help requested about motorPI module
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: Dariush Hampai <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 2 Sep 2025 19:44:58 +0000
Dariush,
It does appear that new C-663 controllers are no longer compatible with the old motorPI module, which uses the VE command to query controller ID strings, and should instead use the motorPIGCS2 module, which uses the *IDN? command to query controller ID strings.
The motorPIGCS2 has an example IOC configuration that can be copied and modified:
https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2Fepics-motor*2FmotorPIGCS2*2Fblob*2Fmaster*2Fiocs*2Fpigcs2IOC*2FiocBoot*2FiocPIGCS2*2FPI_GCS2.cmd&data=05*7C02*7Ctech-talk*40aps.anl.gov*7Ce60052142c834ad6aeb608ddea5932f1*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C638924391003402783*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=US*2FQGKW57Wrv6YhJdxmpyD7wvpJ6UI3SWgUn1GnkoH4*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUl!!G_uCfscf7eWS!ZYqbOz4IFGW5DcWYpalbqHO0Bi4XHwLR_fcY6S0LlRolpSWkZcw1QC0C64QxVscjrbHXogA0PFRQngtuaXxSIEE$
The PIGCS2 driver uses the same call for all the supported controllers:
PI_GCS2_CreateController()
Kevin
Re: help requested about motorPI module Dariush Hampai via Tech-talk
Re: help requested about motorPI module Peterson, Kevin M. via Tech-talk
Prev: ICALEPCS & Collab Meeting Chat Room Blomley, Edmund (IBPT) via Tech-talk
Next: Information request about EPICS training opportunities Manuel Albaladejo Rodriguez via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: help requested about motorPI module Dariush Hampai via Tech-talk
Next: Support for Edwards nXDS 10i Heinz Junkes via Tech-talk
