1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Identifying ioc/machine accessing the PV
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Kuldeep Joshi <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 9 Sep 2025 14:52:37 +0000
Hi Kuldeep,
The IOC does not save information about clients that subscribe to or get values from a PV, but the IOC is designed so that monitors and gets should have almost no effect on the process database anyway. There is no API that provides a list of CA clients currently connected or what channels they have open, although you can see that information in the output printed by the IOCSH command “casr 2”; higher numbers give more detail, and you could redirect the command output to a file if you want to try collecting that. The caPutLog project that Ralph pointed to lets you turn on logging of client puts to an external log-server.
- Andrew
Complexity comes for free, Simplicity you have to work for.
On 9/9/25, 5:06 AM, "Tech-talk" <[email protected]> wrote:
Hello,
I am having a distributed IOC whereby I want to know the device which has accessed the PV. for Read or Write. ie if it was a local ioc access or a CA access from a remote machine.
I plan to use this information for auditing purpose
Kuldeep
Identifying ioc/machine accessing the PV Kuldeep Joshi via Tech-talk
Prev: Re: Identifying ioc/machine accessing the PV Ralph Lange via Tech-talk
Next: Re: RTEMS compilation flag Joel Sherrill via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Windows static build Thomas, Patrick via Tech-talk
