Hi Pete,
Congratulations! I’m hoping we’ll get more RTEMS users to help test out the latest changes for RTEMS 6.
This issue sounds just like a problem that
we have traced to an optimizer bug in GCC. There was a workaround added to the postfix.c file in the 7.0.6 release (in commit
54f2d888) which you might be able to apply if you can’ t use a newer version of Base, it turns off optimization when compiling that memcpy(); you would also
need to add
ARCH_DEP_CFLAGS += -DRTEMS_HAS_ALTIVEC
to your
configure/os/CONFIG.Common.RTEMS-beatnik file to enable it (I assume you’re
using the beatnik BSP).
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
I have built my first RTEMS 5.3 IOC. The IOC includes a transform record which when first tested crashed seemingly when a memcpy was encountered in the transform record calc field parsing during iocInit. Addition of a ‘-fno_builtin’ to the compiler options
seems to have sorted the problem. I was wondering if others had encountered this problem and whether the addition of this particular compiler flag is common with RTEMS IOC’s or have I missed something?
I am using RTEMS 5.3, epics 7.0.7, compiler powerpc-rtems5-g++ (GCC) 7.5.0 20191114 (RTEMS 5, RSB 5.3, Newlib 7947581). To verify the issue I stripped the IOC right back to just one transform record which was enough to show the problem.
Pete
Peter Leicester
Senior Software Systems Engineer
Diamond Light Source Ltd
This e-mail and any attachments may contain confidential, copyright and or privileged material, and are for the use of the intended addressee only. If you are not the intended addressee or an authorised
recipient of the addressee please notify us of receipt by returning the e-mail and do not use, copy, retain, distribute or disclose the information in or attached to the e-mail. Any opinions expressed within this e-mail are those of the individual and not
necessarily of Diamond Light Source Ltd.
Diamond Light Source Limited (company no. 4375679). Registered in England and Wales with its registered office at Diamond House, Harwell Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United Kingdom.
- RE: RTEMS compilation flag Leicester, Pete (DLSLtd, RAL, CEO) via Tech-talk
- RTEMS compilation flag Leicester, Pete (DLSLtd, RAL, CEO) via Tech-talk
Re: RTEMS compilation flag Joel Sherrill via Tech-talk
<2025>
2026
<2025>
2026
