1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: modbus instruments don't provide the correct connection status using asyn check
From: Michael Davidsaver via Tech-talk <[email protected]>
Cc: tech-talk EPICS <[email protected]>
Date: Thu, 11 Sep 2025 10:10:53 -0700
On 9/11/25 08:57, Mark Rivers via Tech-talk wrote:
There is a simple fix. You need to set the asyn option “disconnectOnReadTimeout” to “Y” in the underlying TCP port. In that case whenever a read times out asyn will close the socket, and then it will be disconnected.
Should "Y" become the default?
modbus instruments don't provide the correct connection status using asyn check Antonio Moschini via Tech-talk
Re: modbus instruments don't provide the correct connection status using asyn check Mark Rivers via Tech-talk
Prev: Re: modbus instruments don't provide the correct connection status using asyn check Mark Rivers via Tech-talk
Next: R: modbus instruments don't provide the correct connection status using asyn check Antonio Moschini via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
