1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Help with bumpless IOC reboot, record linking and initialization concepts
From: Marco Filho via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>, Ralph Lange <[email protected]>
Date: Thu, 18 Sep 2025 10:55:05 +0000
Hi, Ralph, thanks for the help!
I added the record
record(bo, "DISBOOT") {
field(DESC, "Disable on IOC boot")
field(ONAM, "DISABLE")
field(ZNAM, "ENABLE")
field(VAL, "1")
field(PINI, "RUNNING")
field(HIGH, "5")
And the field
field(SDIS, "DISBOOT")
To the forwarder record (Not the local nor the global one) and it solved the problem.
It bothers me a bit to add a magic sleep time in the IOC instead of waiting for a known state to complete, but it's the best solution so far without removing the functionality of having hundreds of Local records following what is set in a single global record - without needing at least tens of fanouts or dfanouts.
Also, if I'm not mistaken even if I had fanouts I would still have this same process-at-initialization problem to solve.
Well, the IOC works without changing the hardware state at boot time now.
Thanks a lot!
Marco
From: Tech-talk <[email protected]> on behalf of Ralph Lange via Tech-talk <[email protected]>
Sent: Wednesday, September 17, 2025 20:42
Every CP/CPP input link sets up a local CA monitor.
When you create a CA monitor, you get an initial update when the connection is made.
That initial update on CP/CPP input links processes the record (as CP/CPP means "process on every update").
Multiple CP/CPP input links (e.g., on a calc record) process the record multiple times. (!)
Using the disable mechanism is a possible workaround. Point all the records that you want to quiet down with their SDIS links to a single disable-after-boot control record, and have that control record enable the others after the CP/CPP links have connected - time-based (= after a little while) is the simplest way.
Cheers,
~Ralph
Re: Help with bumpless IOC reboot, record linking and initialization concepts Johnson, Andrew N. via Tech-talk
Re: Help with bumpless IOC reboot, record linking and initialization concepts Ralph Lange via Tech-talk
Prev: Re: Help with bumpless IOC reboot, record linking and initialization concepts Ralph Lange via Tech-talk
Next: Re: Help with bumpless IOC reboot, record linking and initialization concepts Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
