1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Problem with drvAsynIPPortConfigure
To: Dariush Hampai <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 18 Sep 2025 15:37:46 +0000
Hi Dariush,
I think you have the order of your dbd files wrong.  They should be in this order:
mdrive_1IOC_DBD += asyn.dbd
mdrive_1IOC_DBD += drvAsynIPPort.dbd
mdrive_1IOC_DBD += stream-base.dbd
Is stream-base.dbd part of the StreamDevice module, or is that something local to your site?  The files you listed did not include base.dbd, which should come first.  So I think it should really be:
mdrive_1IOC_DBD += base.dbd
mdrive_1IOC_DBD += stream.dbd
-----Original Message-----
Sent: Thursday, September 18, 2025 10:21 AM
To: [email protected]; Mark Rivers <[email protected]>
Subject: Problem with drvAsynIPPortConfigure
hi Community,
I'm writing an IOC for industrial motor driver:
I prepare the IOC, in particular:
1) in the configure/RELASE there is
SUPPORT=$(EPICS_BASE)/synApps_6_3/support
ASYN=$(SUPPORT)/asyn-R4-44-2
STREAM=$(SUPPORT)/StreamDevice-2-8-24
EPICS_BASE = /home/xlabsrv2/epics
2) in the mdrive_1IOC/src/Makefile there is mdrive_1IOC_DBD += stream-base.dbd mdrive_1IOC_DBD += drvAsynIPPort.dbd mdrive_1IOC_DBD += asyn.dbd
mdrive_1IOC_LIBS += stream
mdrive_1IOC_LIBS += asyn
3) in the mdrive_1IOC/Db/Makefile there is DB += mdrive_1IOC.proto DB += mdrive_1IOC.db DB += mdrive_1IOC.val
4) in the mdrive_1IOC/Db/mdrive_1IOC.val there is file db/mdrive_1IOC.db {
     pattern { card, axis, ASYNPORT, MOT, EGU, homing, MRES, direct }
         { 1, 1 , "ip_x", "mdrive_x", mm, 1, 411, + } }
5) in the st.cmd there is
epicsEnvSet ("STREAM_PROTOCOL_PATH", "${TOP}/db") epicsEnvSet ("PORT_mdrive_x", "ip_x")
drvAsynIPPortConfigure($(PORT_mdrive_x), "100.100.0.23:503")
asynOctetSetInputEos($(PORT_mdrive_x),0,"\n\r")
asynOctetSetOutputEos($(PORT_mdrive_x),0,"\n\r")
asynSetTraceMask($(PORT_mdrive_x),-1,0x9);
asynSetTraceIOMask($(PORT_mdrive_x),-1,0x2)
These are the configurations. After make (all is ok), executing the st.cmd I receive the following error
[xlabsrv2@xlabsrv2 iocmdrive_1IOC]$ ./st.cmd #!../../bin/linux-x86_64/mdrive_1IOC
< envPaths
epicsEnvSet("IOC","iocmdrive_1IOC")
epicsEnvSet("TOP","/home/xlabsrv2/epics/IOCs/mdrive_1IOC")
epicsEnvSet("SUPPORT","/home/xlabsrv2/epics/synApps_6_3/support")
epicsEnvSet("ASYN","/home/xlabsrv2/epics/synApps_6_3/support/asyn-R4-44-2")
epicsEnvSet("STREAM","/home/xlabsrv2/epics/synApps_6_3/support/StreamDevice-2-8-24")
epicsEnvSet("EPICS_BASE","/home/xlabsrv2/epics")
cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC"
"/home/xlabsrv2/epics/IOCs/mdrive_1IOC/db")
#X Axis
drvAsynIPPortConfigure(ip_x, "100.100.0.23:503") ERROR st.cmd line 36: Command drvAsynIPPortConfigure not found.
asynOctetSetInputEos(ip_x,0,"\n\r")
ERROR st.cmd line 37: Command asynOctetSetInputEos not found.
asynOctetSetOutputEos(ip_x,0,"\n\r")
ERROR st.cmd line 38: Command asynOctetSetOutputEos not found.
asynSetTraceMask(ip_x,-1,0x9);
ERROR st.cmd line 40: Command asynSetTraceMask not found.
asynSetTraceIOMask(ip_x,-1,0x2)
ERROR st.cmd line 41: Command asynSetTraceIOMask not found.
dbLoadDatabase "dbd/mdrive_1IOC.dbd"
mdrive_1IOC_registerRecordDeviceDriver pdbbase ## Load record instances
#dbLoadRecords("db/mdrive_1IOC.db","user=xlabsrv2")
dbLoadTemplate("db/mdrive_1IOC.val")
dbLoadTemplate: Too many values given, line 14.
cd "/home/xlabsrv2/epics/IOCs/mdrive_1IOC/iocBoot/iocmdrive_1IOC"
iocInit
Starting iocInit
## EPICS R7.0.8.2-DEV
## Rev. R7.0.8.1-142-g144f9756eac4e800f18d
## Rev. Date Git: 2025-02-05 10:16:16 -0600 ############################################################################
2025/09/18 16:04:01.785392 _main_ Cannot find a bus named 'ip_x' for 'mdrive_x:model'
2025/09/18 16:04:01.785498 _main_ mdrive_x:model: Can't attach to bus ip_x 0
2025/09/18 16:04:01.785517 _main_ mdrive_x:model: Record initialization failed
## Start any sequence programs
#seq sncxxx,"user=xlabsrv2"
epics>
searching in previous threads I found missing the "drvAsynIPPort.dbd" in src/Makefile, but I already put it. Moreover I use "make clean all", and (to be sure) in this case I also remove db, dbd, and lib folders to restart with a clean make
where ma I wrong?
thank you in advance!!!
Dariush
p.s.: all other IOCs using drvAsynIPPortConfigure working properly...
Dr. Dariush Hampai, PhD
INFN - LNF
X-Lab Frascati
Via E. Fermi, 54 (ex 40)
I-00044 Frascati (RM)
Italy
Mail Address:
XLab-Frascati
LNF-INFN
Casella Postale 13
Frascati (RM)
Italy
Room:	+39.06.9403.5248
Lab.:	+39.06.9403.2286
Mob.:	+39.06.9403.8025
Fax.:	+39.06.9403.2597
Re: Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
Re: Problem with drvAsynIPPortConfigure Henrique F. Simoes via Tech-talk
Prev: Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
Next: Re: Problem with drvAsynIPPortConfigure Dariush Hampai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
