1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Fast stream-device IOC suddenly disconnects
To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 28 Sep 2025 14:15:53 +0000
Hi Abdalla,
Many terminal servers provide a Web page where you can see the traffic statistics for each port.  When it hangs up is the terminal server still seeing traffic on that port?
Sent: Sunday, September 28, 2025 9:08 AM
To: Mark Rivers <[email protected]>; [email protected] <[email protected]>
Hi Mark
Thanks for the info. I forgot to mention that the device is a serial port connected to a terminal server, and the device has been tested locally streaming data for periods longer than what we have so I don't think it just stopped sending data.
Best Regards
Abdalla.
Sent: Sunday, September 28, 2025 5:02:36 PM
To: [email protected] <[email protected]>; Abdalla Ahmad <[email protected]>
Hi Abdalla,
It looks like the device streams data without needing to send a command, i.e. it is not a write/read operation, correct?
If it freezes then that suggests that the device has stopped sending data for some reason.  That should mean that the asyn read operation timed out, and StreamDevice should be reporting that?
You can try adding this to the startup script after drvAsynIPPortConfigure:
asynSetOption($(PORT), 0, "disconnectOnReadTimeout", "Y")
That will disconnect the port when a read times out, which is equivalent to writing 0 to the CNCT field.
From: Tech-talk <[email protected]> on behalf of Abdalla Ahmad via Tech-talk <[email protected]>
Sent: Sunday, September 28, 2025 6:08 AM
Subject: Fast stream-device IOC suddenly disconnects
Hi
We have a device streaming data at 200 Hz controlled with stream device, parses the streamed data and writes to corresponding PVs. The problem is that every day or two, the readings freeze. At first I had to restart the IOC but I noticed that the IOC does not show any error so I re-connect the asyn port through writing 0 to the CNCT field and it worked. The st.cmd file has the port configured:
drvAsynIPPortConfigure(“PORT”, “ip-address:port-number”, 0, 0, 0)
What could be the issue here? I am using EPICS base 7.0.9 and latest version of all modules.
Best Regards,
Abdalla Al-Dalleh
Control Engineer
SESAME
Fast stream-device IOC suddenly disconnects Abdalla Ahmad via Tech-talk
Re: Fast stream-device IOC suddenly disconnects Mark Rivers via Tech-talk
Re: Fast stream-device IOC suddenly disconnects Abdalla Ahmad via Tech-talk
Prev: Re: Fast stream-device IOC suddenly disconnects Mark Rivers via Tech-talk
Next: Re: EPICS CA and PVA across subnets Guruswamy, Tejas via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Prev: Re: Fast stream-device IOC suddenly disconnects Zimoch, Dirk via Tech-talk
Next: Re: Fast stream-device IOC suddenly disconnects Mark Rivers via Tech-talk
