1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Strange error in building IOC with Sequencer support
To: David Dudley <[email protected]>
Date: Mon, 29 Sep 2025 15:23:41 +0000
It sounds like your application was not built with the sequencer dbd files.
Sent from my iPhone
On Sep 29, 2025, at 10:15 AM, Dudley, David via Tech-talk <[email protected]> wrote:
I’m trying to build an IOC that uses a *.st sequence file.
For some reason, when it builds and I start it up, there are no sequence commands in the help listing.
Turns out, the example program does the same for me.
The .st program gets built, and linked in I believe, theres just no commands to use it.
Any idea what silly thing I missed?
Later-
David
Strange error in building IOC with Sequencer support Dudley, David via Tech-talk
Prev: Strange error in building IOC with Sequencer support Dudley, David via Tech-talk
Next: Re: EPICS CA and PVA across subnets Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: duplicated main Dudley, David via Tech-talk
