Hi Graeme,
I don’t know of a general solution for your problems, but the epics-synApps module (https://github.com/EPICS-synApps) provides 2 useful tools:
- assemble_synApps “Used to pull a user-defined set of EPICS modules at given tags and package them into a single synApps directory that will build with
a single 'make' command.”
You can instruct it to create a full clone, so that in the future each module can be updated independently.
https://github.com/EPICS-synApps/assemble_synApps
- support: Top-level Makefile supports “make release”. You edit support/configure/RELEASE to define the versions and locations of each module. “make
release” will update the configure/RELEASE files in all modules to be consistent with support/configure/RELEASE.
These are used by most beamlines at the APS.
On Behalf Of Graeme Winter via Tech-talk
Sent: Tuesday, October 7, 2025 1:56 PM
To: [email protected]
Subject: Basic EPICS bootstrap (rant)
Good afternoon
Working through
It really feels like this is something which could be made _much_ easier by writing a kind of bootstrap script but also by the configure process being able to pick up stuff from the environment rather than having to hard-code every location
multiple times in every configuration file (where the defaults are of course where the author does _their_ epics development) - the need for them to all correctly cross-reference is also an irritation
Before I scrape another few mm off my already suffering sanity -
- _has_ anyone got a bootstrap script which will clone / install all the necessary / regular support modules
- am I holding it wrong / reading the wrong getting started guide
I note I can conda install epics-base but this _only_ gives epics base
That rant to one side, also, does anyone know how to address a missing symbol issue like
Undefined symbols for architecture arm64:
"_pvar_func_vxi11RegisterCommands", referenced from:
_cryo1_registerRecordDeviceDriver in cryo1_registerRecordDeviceDriver.o
ld: symbol(s) not found for architecture arm64
The symbol is indeed missing and would appear to be from asyn/vxi11/drvVxi11.c but does not appear to be built
This got me thinking I should re-do the NN steps to get back to here which then got me wondering about process itself…
- Re: Basic EPICS bootstrap (rant) Graeme Winter via Tech-talk
- Basic EPICS bootstrap (rant) Graeme Winter via Tech-talk
xspress3 internal triggering issue Keith Surrena via Tech-talk
<2025>
2026
<2025>
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
