1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Finding out what's commanding motor move?
To: "J. Lewis Muir" <[email protected]>, EPICS Tech-Talk <[email protected]>
Date: Fri, 10 Oct 2025 16:51:14 +0000
Hi Lewis,
You can use the casr command at the IOC shell to see what clients have connected to that PV.
epics> casr 2
Channel Access Server V4.13
2 clients connected:
    TCP client at 164.54.160.82:37920 'corvette':
        User 'epics', V4.13, Priority = 0, 150 Channels
        Channel: '13MCBOX:USBCTR:PulseGen2Run'
        Channel: '13MCBOX:USBCTR:Bi4.VAL'
        Channel: '13MCBOX:USBCTR:Bi5.VAL'
    TCP client at 164.54.160.227:51915 'Tahoe':
        User 'rivers', V4.13, Priority = 0, 5 Channels
        Channel: '13MCBOX:MCS1:Dwell'
        Channel: '13MCBOX:MCS1:NuseAll'
        Channel: '13MCBOX:MCS1:EraseStart'
        Channel: '13MCBOX:MCS1:StopAll'
        Channel: '13MCBOX:MCS1:mca2'
CAS-TCP server on 0.0.0.0:5064 with
    CAS-UDP name server on 0.0.0.0:5064
        Last name requested by 164.54.160.202:61180:
        User '', V4.13, Priority = 0, 0 Channels
Sending CAS-beacons to 1 address:
    164.54.160.255:5065
In this case there are 2 clients, one of corvette and one on tahoe.
casr is part of EPICS base, and so you can run it without needing to restart the IOC.
Another utility is CaPutLog.
https://github.com/epics-modules/caPutLog/blob/master/docs/index.rst
That will log all Channel Access put operations.  It is a separate module, so you need to build your IOC with it.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of J. Lewis Muir via Tech-talk
Sent: Friday, October 10, 2025 11:27 AM
To: EPICS Tech-Talk <[email protected]>
Subject: Finding out what's commanding motor move?
Hi!
I've got an EPICS motor that appears to be being commanded to move in increments of 0.001 mm every ~0.9 s, sometimes pausing maybe once a minute for 3-5 s and then continuing, and I can't figure out where this is coming from.  Nothing should be commanding the motor to move.  Below is a short camonitor output showing this.  Has anyone seen this before, or does anyone know how I could track this down?
The environment is the following:
* Architecture: x86_64
* EPICS 7.0.8.1
* motor 7.3.1
* motorAcsMotion 2.2 (+ commits up to c2d67e7, + patches for 719d3ca and
  f4442ee)
* Motor controller: ACS SPiiPlusEC
I could restart the IOC or the motor controller and see if the problem goes away, but I'm also very puzzled by this and not wanting to lose my chance to figure out what is happening.
I wondered if maybe an MEDM client could have gone wrong, or maybe at some point a user had clicked the MEDM motor tweak button rapidly or who knows what, and something has queued up move requests, or an MEDM client has a bug and is sending requests.  I tried killing MEDM clients, but the behavior remains.  (It's possible, though, that I didn't kill all of the MEDM clients.)  And of course, this could have nothing to do with MEDM at all.
$ camonitor 17idb:m49.{VAL,RBV}
17idb:m49.VAL                  2025-10-10 09:49:09.164067 0.3198
17idb:m49.RBV                  2025-10-10 09:49:09.164067 0.319806
17idb:m49.VAL                  2025-10-10 09:49:09.811336 0.3208
17idb:m49.RBV                  2025-10-10 09:49:09.942664 0.320808
17idb:m49.RBV                  2025-10-10 09:49:10.048250 0.320799
17idb:m49.VAL                  2025-10-10 09:49:10.694218 0.3218
17idb:m49.RBV                  2025-10-10 09:49:10.823829 0.321805
17idb:m49.RBV                  2025-10-10 09:49:10.929981 0.321801
17idb:m49.VAL                  2025-10-10 09:49:11.575012 0.3228
17idb:m49.RBV                  2025-10-10 09:49:11.710083 0.322803
17idb:m49.RBV                  2025-10-10 09:49:11.816005 0.322795
17idb:m49.VAL                  2025-10-10 09:49:12.463081 0.3238
17idb:m49.RBV                  2025-10-10 09:49:12.488690 0.322803
17idb:m49.RBV                  2025-10-10 09:49:12.594706 0.323805
17idb:m49.VAL                  2025-10-10 09:49:13.346730 0.3248
17idb:m49.RBV                  2025-10-10 09:49:13.372604 0.323801
17idb:m49.RBV                  2025-10-10 09:49:13.478568 0.324807
17idb:m49.RBV                  2025-10-10 09:49:13.584573 0.324803
17idb:m49.VAL                  2025-10-10 09:49:14.229819 0.3258
17idb:m49.RBV                  2025-10-10 09:49:14.254400 0.324794
17idb:m49.RBV                  2025-10-10 09:49:14.360413 0.325805
17idb:m49.VAL                  2025-10-10 09:49:15.112347 0.3268
17idb:m49.RBV                  2025-10-10 09:49:15.138748 0.3258
17idb:m49.RBV                  2025-10-10 09:49:15.244889 0.326806
17idb:m49.RBV                  2025-10-10 09:49:15.351075 0.326794
Thank you!
Lewis
RE: Finding out what's commanding motor move? Mark Rivers via Tech-talk
Re: Finding out what's commanding motor move? J. Lewis Muir via Tech-talk
Prev: Finding out what's commanding motor move? J. Lewis Muir via Tech-talk
Next: RE: Finding out what's commanding motor move? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
