1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Compile errors in 7.0.9
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Graeme Elliner <[email protected]>
Date: Wed, 22 Oct 2025 18:40:00 -0700
On 10/22/25 12:05 AM, Graeme Elliner wrote:
Hi Michael
Thanks for getting back to me and 632 has confirmed the iocLogServer issue
But it’s the other one I’m having issues with
../dbStatic/dbStaticLib.c: In function ‘dbDumpDevice’:
../dbStatic/dbStaticLib.c:3459:36: error: initialization of ‘long int (**)(void)’ from incompatible pointer type ‘long int (**)(int)’ [-Wincompatible-pointer-types]
3459 |                 DEVSUPFUN *pfunc = &pdevSup->pdset->report;
I am able to successfully build the 7.0 branch in an ubuntu 25.10 environment.
Best Regards,
Graeme Elliner
XDS Oxford Limited
Sent: 21 October 2025 19:01
Cc: [email protected]
[EXTERNAL]
see https ://github.com/epics-base/epics-base/issues/632
On 10/21/25 7:41 AM, Graeme Elliner via Tech-talk wrote:
Hi
I’ve just run into two compile errors while trying to install Epics 7.0.9 on Ubuntu 25
../log/iocLogServer.c: In function ‘acceptNewClient’:
../log/iocLogServer.c:483:14: error: expected identifier or ‘(’ before ‘true’
  483 |         long true;
../log/iocLogServer.c:484:14: error: lvalue required as left operand of assignment
  484 |         true = 1;
../log/iocLogServer.c:490:25: error: lvalue required as unary ‘&’ operand
  490 |                 (char *)&true,
This one was relatively straight forward, in iocLogServer.c I just renames true within the acceptNewClient function to tr, this fixed this issue – I assume the compiler was seeing true as True.
I have not been able to fix the next one and could do with some assistance
Best Regards,
Graeme Elliner
Senior Control & Electrical Engineer
XDS Oxford Limited
Tel: 01865 320311 Direct Dial
Tel: 01865 320300 Switchboard
A green and blue logo
Description automatically generated
(formerly trading as FMB Oxford)
Visit us at:
www.xds-oxford.com
www.linkedin.com/company/xds-oxford
www.facebook.com/XDSOxford
www.x.com/XDS_Oxford
 P Before you print think about the ENVIRONMENT
XDS Oxford Limited is registered in England and Wales, Company number 04138193.
Registered office address: Unit 1 Ferry Mills, Osney Mead, Oxford, Oxfordshire, United Kingdom, OX2 0ES.
This e-mail message may contain confidential information and is intended for the addressee only. If you are not the intended recipient, please notify the sender by return e-mail and delete this message immediately.
Reproduction, dissemination or distribution of this message is prohibited unless authorised by the sender. The views expressed by the sender are not necessarily those of XDS Oxford Limited.
This e-mail has passed through Microsoft's Exchange Online Protection services. XDS Oxford Limited accepts no responsibility for any viruses not revealed.
Compile errors in 7.0.9 Graeme Elliner via Tech-talk
Re: Compile errors in 7.0.9 Michael Davidsaver via Tech-talk
RE: Compile errors in 7.0.9 Graeme Elliner via Tech-talk
Prev: RE: Compile errors in 7.0.9 Graeme Elliner via Tech-talk
Next: info tag asyn:READBACK doesn't work with record in OUT field of calcoout Marco Filho via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
