1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Running EPICS on RTEMS/MVME3100
From: "Lorelli, Jeremy via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Marks, Nicholas" <[email protected]>
Date: Thu, 23 Oct 2025 22:28:43 +0000
Hi Nicholas,
RTEMS 6.2+ should resolve at least one of these issues. There was a bug where the i2c driver for the ds1375 RTC would steal fd 0 before stdin/stdout/stderr were initialized.
I don't think 6.2 has been tagged just yet, so you'll need to build the 6 branch directly.
Cheers,
Jeremy
From: Tech-talk <[email protected]> on behalf of Marks, Nicholas via Tech-talk <[email protected]>
Sent: Thursday, October 23, 2025 3:12 PM
To: [email protected] <[email protected]>
Subject: Running EPICS on RTEMS/MVME3100
Hello,
Has anyone succeeded recently in getting an IOC to run on RTEMS on the MVME3100?  I've been trying but haven't had much luck. I have built RTEMS 6.1 using the RTEMS source builder with the MVME3100 BSP and I have successfully run several of the provided test applications (https://github.com/RTEMS/rtems/tree/main/testsuites/samples). I also built EPICS base 7.0.9 for RTEMS-mvme3100, however any EPICS applications I create do not work. I believe the failure is during BSP initialization before the IOC code even enters the picture since if I remove everything from the IOC's main function except a single printf, the same crash is present, and no print. I've pasted the VME console output below this message.
Note that the console hangs for several minutes after this line "ds1375_probe (open): No such file or directory" before printing the
""%s" is not a valid command pathname." message, which comes from either
base/modules/libcom/RTEMS/score/rtems_init.c
or
base/modules/libcom/RTEMS/posix/rtems_init.c
When running the RTEMS test programs that work, the "ds1375_probe..." line is not present.
Any suggestions would be appreciated. Thank you.
MVME3100> go -a4000000
Welcome to rtems-6.1.0 (PowerPC/Generic (no FPU)/mvme3100)
BSP: mvme3100, CVS Release ($Name$)
CPU 0x8020 - rev 0x20
Additionnal boot options are H
Initial system stack at 465df0
Going to start PCI buses scanning and initialization
Board Type: MVME3100-1263 (S/N EFDD3B6)
External (=PCI Bus) Clock Freq   :   66666666 Hz
Core Complex Bus (CCB) Clock Freq:  333333330 Hz
CPU Clock Freq:                     166666665 Hz
Ethernet 0                  EC:9E:CD:19:41:FF
Ethernet 1                  EC:9E:CD:19:42:00
Ethernet 2                  EC:9E:CD:19:42:01
Number of PCI buses found is : 3
BUS:SLOT:FUN  VENDOR-DEV_ID: COMMAND STATUS BASE_ADDR0 BASE_ADDR1 IRQ_PIN ->
  0:0x00:0    0x1057-0x0008:  0x0006 0x20b0 0x80000000 0x00000000       0 ->
  0:0x11:0    0x10e3-0x0148:  0x0146 0x02b0 0x80100004 0x00000000       1 ->
  0:0x12:0    0x10b5-0x6520:  0x0147 0x02b0 0x00000000 0x00000000       0 ->
  0:0x13:0    0x10b5-0x6520:  0x0147 0x02b0 0x00000000 0x00000000       0 ->
  0:0x14:0    0x1095-0x3124:  0x01c7 0x02b0 0x80400004 0x00000000       1 ->   2 (=0x0
  2:0x00:0    0x1033-0x0035:  0x0146 0x0210 0x80300000 0x00000000       1 ->   4 (=0x0
  2:0x00:1    0x1033-0x0035:  0x0146 0x0210 0x80301000 0x00000000       2 ->   5 (=0x0
Memory:                             536870912 bytes
Cleared PCI errors: pci_stat was 0x20b0
OpenPIC Version 1.2 (1 CPUs and 56 IRQ sources) at 0x3775135744
OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 0
OpenPIC timer frequency is 41666666 Hz
MSR is 0x00001000, TCR 0x04000000
Exit from bspstart
Tundra Tsi148 PCI-VME bridge detected at 0x80100000, IRQ 0
Tsi148 Outbound Ports:
Port  VME-Addr   Size       PCI-Adrs   Mode:
0:    0x20000000 0x0e000000 0xc0000000 A32, SUP, D32, SCT
1:    0x00000000 0x00ff0000 0xcf000000 A24, SUP, D32, SCT
2:    0x00000000 0x00010000 0xcfff0000 A16, SUP, D32, SCT
7:    0x00000000 0x01000000 0xce000000 CSR, SUP, D32, SCT
Tsi148 Inbound Ports:
0:    0xc0000000 0x20000000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
vmeTsi148 IRQ manager: looking for registers on VME...
Trying to find CSR on VME...
vmeTsi148 - IRQ manager using VME CSR to flush FIFO
libi2c: Library not initialized
Registering mpc8540 i2c bus driver :No such file or directory
Registering /dev/console as minor 0 (==/dev/ttyS0)
*** FATAL ***
fatal source: 11 (RTEMS_FATAL_SOURCE_PANIC)
fatal code: 3444772 (0x00349024)
RTEMS version: 6.1.0.not-released
RTEMS tools: 13.3.0 20240521 (RTEMS 6, RSB no-repo, Newlib 1b3dcfd)
executing thread ID: 0x0b010001
Copyright(C)2008-2013,Emerson Network Power-Embedded Computing,Inc.
All Rights Reserved
Copyright Motorola Inc. 1999-2007, All Rights Reserved
MOTLoad RTOS Version 2.0,  PAL Version 1.2 RM04
Wed Nov  6 17:17:43 MST 2013
MPU-Type             =MPC8540
MPU-Int Clock Speed  =833MHz
MPU-CCB Clock Speed  =333MHz
MPU-DDR Clock Speed  =166MHz
MPU-PCI Clock Speed  =66MHz, PCI, 64-bit
MPU-Int Cache(L2) Enabled, 256KB, L2CTL =A8000300
Reset/Boot Vector    =Flash0
Local Memory Found   =20000000 (&536870912)
User Download Buffer =0159D000:0179CFFF
MVME3100>
Running EPICS on RTEMS/MVME3100 Marks, Nicholas via Tech-talk
Prev: Running EPICS on RTEMS/MVME3100 Marks, Nicholas via Tech-talk
Next: Re: Running EPICS on RTEMS/MVME3100 Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
