Hi Keith,
Those commands are not supported in ADPilatus.
I just searched this Dectris camserver document for the string “retrigger” and it does exist.
https://media.dectris.com/User_Manual-PILATUS2-V1_4.pdf
Where did you find the documentation on the retrigger command?
I do see the documentation on the Tau command. ADPilatus currently only reads Tau, it does not allow setting it.
However, you can set it via the OPI screens as follows:
- In the screen pilatusDetector.adl open the Debugging/asyn record screen.
- Change the port on that screen to camserver (if that is what you called it in the startup script).
- Open the More/asynOctet interface I/O screen
- In the Output/ASCII screen type the camserver command. You will see the response in the Input/ASCII field.
I just tested this typing “Tau” to read the current setting, and I received the correct response.
Keith Surrena via Tech-talk
Sent: Tuesday, October 28, 2025 9:51 AM
To: [email protected]
Subject: areadetector PV for pilatus3 retrigger and count-rate correction
Are there PVs that exist for adjusting these parameters? Alternatively, since I know the specific camserver commands, is there a PV I can use to manually send strings to camserver? I noticed that there is a StringToCamserver_RBV, which
piques my interest.
Keith Surrena
Research Support Specialist
Cornell High Energy Synchrotron
Source
