Hi! I have a Modbus-TCP device which requires a so called "authorization" to be performed BEFORE any actual I/O can take place; without such an authorization all register writes and even reads result in exception 2 ("illegal data address"). The "authorization" consists of several register reads and writes, in specific order: 1. Write INT32_LE:0x89ABCDEF to holding registers 0x2100,0x2101 2. Write INT32_LE:0x01234567 to holding registers 0x2102,0x2103 3. Write 0 to holding register 0x2104 4. Read discrete input 0x2200 Is there some mechanism to perform this sequence immediately upon connect? Looking at "modbus" module documentation, I see nothing relevant. Thanks in advance! Vitalii
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
