1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: Disable alarm at IOC via PVAccess
From: Michael Davidsaver via Tech-talk <[email protected]>
To: David Bracey <[email protected]>
Date: Thu, 20 Nov 2025 20:06:20 -0800
Hi David,
I'm wondering if there is a jargon mismatch here.  When you say "disable an alarm", do you mean in sense that "this condition should never result in an alarm"?  Or instead "Operations has evaluated the situation, taken action, and would like to focus on something else now thank you very much"?
On 11/20/25 1:47 PM, David Bracey via Tech-talk wrote:
  • A PV really has four distinct alarms – all four severities would need to be set NO_ALARM to really “disable alarms” for the PV
  • Oh, many many more conditions than this!  Off hand there are calculation alarms, undefined value (UDF), and scan disable.  Search through the epics-base source for "recGblSetSevr".  And there are even more driver specific conditions.
  • To re-enable alarms, you would have needed to have remembered the prior value to restore it (or just YOU’LL GET MAJOR AND LIKE IT)
  • It sounds to me like you don't want to do this :)
    I suspect that what you want would in the epics lingo is to "acknowledge" an alarm (the second definition above).  Originally this was done in the IOC, and still can be.  However, these days it is typically handled in an alarm manager service.  cf. the Phoebus Alarm Server (or its wonderfully named predecessor BEAST).
    https://control-system-studio.readthedocs.io/en/latest/services/alarm-server/doc/index.html
    Disable alarm at IOC via PVAccess David Bracey via Tech-talk
    Re: Disable alarm at IOC via PVAccess Pierrick Hanlet via Tech-talk
    Re: Disable alarm at IOC via PVAccess David Bracey via Tech-talk
    Re: Disable alarm at IOC via PVAccess Kasemir, Kay via Tech-talk
    Prev: Re: Disable alarm at IOC via PVAccess David Bracey via Tech-talk
    Next: Re: Disable alarm at IOC via PVAccess Kasemir, Kay via Tech-talk
    Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
