1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Alarm stuck in "Async in progress" even after record processing is fine
From: Marco Filho via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 21 Nov 2025 15:19:00 +0000
Hi, all.
I'm not sure if this is a bug or a feature: I have an IOC that hangs the record processing when the hardware disconnects. This causes the record to process over itself more than ten times, generating an "Async in progress" alarm message.
When the hardware finally reconnects, the record processing gets back to normal again, but the alarm message never disappears. AMSG and NAMSG keep displaying "Async in progress". ACKT is YES and ACKS is INVALID, although SEVR is already in NO_ALARM.
Shouldn't AMSG go to an empty string? Is there a proper way to acknowledge this alarm?
I found in the documentation:
"The ACKT field specifies if it is necessary to acknowledge transient alarms."
But I couldn't find how is this acknowledgment made.
Thanks for any help,
Marco
Re: Alarm stuck in "Async in progress" even after record processing is fine Jure Varlec via Tech-talk
Re: Alarm stuck in "Async in progress" even after record processing is fine Johnson, Andrew N. via Tech-talk
Prev: Re: Disable alarm at IOC via PVAccess Kasemir, Kay via Tech-talk
Next: Re: [EXTERNAL] Disable alarm at IOC via PVAccess Hartman, Steven via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: WEISS - Web EPICS Interface & Synoptic Studio André Favoto via Tech-talk
Next: Re: Alarm stuck in "Async in progress" even after record processing is fine Jure Varlec via Tech-talk
