1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: [EXTERNAL] Disable alarm at IOC via PVAccess
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 21 Nov 2025 17:23:23 +0100
It's a design thing and needs to be looked at for every use case.
I would always argue that "offline on purpose" is a temporary interpretation of an alarm, and that kind of silencing should be done in the alarm handling system, not in the low-level I&C.
Value alarm levels that depend on the mode of operation are definitely closer to the system and probably better handled in the database.
A soft database that combines and pre-processes values/alarms is often a good idea and sometimes you can't even do without. (E.g., "the sum of power generated by our 12 RF units must be between X and Y.", which is an error on a group of devices.)
Cheers,
~Ralph
Disable alarm at IOC via PVAccess David Bracey via Tech-talk
Re: Disable alarm at IOC via PVAccess Pierrick Hanlet via Tech-talk
Re: Disable alarm at IOC via PVAccess David Bracey via Tech-talk
Re: Disable alarm at IOC via PVAccess Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Disable alarm at IOC via PVAccess Hartman, Steven via Tech-talk
Prev: Re: [EXTERNAL] Disable alarm at IOC via PVAccess Hartman, Steven via Tech-talk
Next: Re: Disable alarm at IOC via PVAccess David Bracey via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: Re: [EXTERNAL] Disable alarm at IOC via PVAccess Maren Purves via Tech-talk
