1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Re: Manta G-235B Camera
From: Steven Hunt via Tech-talk <[email protected]>
Date: Mon, 24 Nov 2025 13:59:25 -0800
Hi Mark,  thanks ....
In the past (pre-vimba)  we had  cam1:TriggerDelay - although hardly ever touched it - is that PV still valid?  if so what are the units?
Also tried cam1:ShutterOpenDelay and cam1:ShutterCloseDelay .....  never used these in the past, not sure how they are used, and what choice should be made to cam1:ShutterMode to make use of them?
Best regards
On Mon, Nov 24, 2025 at 1:47 PM Mark Rivers <[email protected]> wrote:
Steve, please be specific about what PV you are referring to.  Do you mean $(P)$(R)ShutterOpenDelay, $(P)$(R)ShutterCloseDelay, or some other PV with the string “delay” in it?
From: Tech-talk <[email protected]> On Behalf Of Steven Hunt via Tech-talk
Sent: Monday, November 24, 2025 2:01 PM
To: tech-talk <[email protected]>
Subject: Manta G-235B Camera
Hi, can anyone explain the usage of delay for Mantra cameras using the vimba driver?  the EDM screen says units are seconds - is that correct?   I  set this to a value that should not acquire the beam, but it still does so.
Thanks in advance
RE: Manta G-235B Camera Mark Rivers via Tech-talk
Manta G-235B Camera Steven Hunt via Tech-talk
Prev: RE: Manta G-235B Camera Mark Rivers via Tech-talk
Next: RE: Manta G-235B Camera Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
