1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: RE: Asyn record CNCT field does not update
To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 25 Nov 2025 17:57:47 +0000
Hi Abdalla,
Sorry, I missed the fact that you are using UDP, not TCP.  In that case there is no permanent connection established between your driver and the device.  Each UDP read or write operation is completely independent.  Your driver will need to implement the logic which might be, for example, after 5 unsuccessful I/O attempts call pasynManager ->exceptionDisconnect() to tell asynManager that the device is disconnected.  Since you have set autoConnect=1 asynManager will periodically call the connect() method in your driver.  If your driver finds that the device is available, it then calls pasynManager->exceptionConnect().
From: Tech-talk <[email protected]> On Behalf Of Abdalla Ahmad via Tech-talk
Sent: Tuesday, November 25, 2025 11:37 AM
To: [email protected]
Subject: Asyn record CNCT field does not update
Hi
I developed an asynPortDriver to control a device through UDP, I want to use asynRecord CNCT field to monitor the port connection state whether the device is connected or not. The driver is configured with auto connect flag set to 1. When I monitor the field and disconnect the device, I get error message indicating IO error, but the field does not change to disconnect. I am I missing other settings to be done?
Best Regards,
Abdalla.
RE: Asyn record CNCT field does not update Abdalla Ahmad via Tech-talk
Prev: RE: Asyn record CNCT field does not update Mark Rivers via Tech-talk
Next: Re: Get notified of alarms internally to IOC w/o requiring record fields Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Next: RE: Asyn record CNCT field does not update Abdalla Ahmad via Tech-talk
