1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: About errors in controlling the motor controller.
To: "[email protected]" <[email protected]>, White <[email protected]>
Date: Fri, 28 Nov 2025 14:58:04 +0000
Hi White,
That is probably not true for the EPICS driver.  There is a convention I never understood where some Modbus software uses addresses that are 1 bigger than the physical address.  But the EPICS driver uses the physical address, so you should use the addresses shown in the spreadsheet.
That means:
I think you need to change this to Modbus start address to 0, not 1.
You have set the SCAN field of the bo record to I/O Intr.  That is not correct that is only for input records.  It should be Passive, which is the default, so you can omit that field.
Did you check for error messages on the IOC console?
You can try processing that record and see more details about the record with this command:
dbtr FMC01:HOMING_TRIGGER 2
From: Tech-talk <[email protected]> on behalf of White via Tech-talk <[email protected]>
Sent: Friday, November 28, 2025 3:17 AM
To: [email protected] <[email protected]>
Subject: About errors in controlling the motor controller.
Hi
I am using EPICS to remotely control a stepper motor controller (IP: 192.168.0.11), which supports the Modbus-TCP protocol. I want to use the homing trigger function for axis 0. My st.cmd file and db file are as follows, and it runs without errors. but the PV does not connect successfully. The same situation applies to relative motion and absolute motion commands.the Modbus addresses are in the attachment, ( the vendor said that the addresses need to be incremented by one)
drvAsynIPPortConfigure(“CAT2”,”192.168.0.11:502”,0,0,0)
modbusInterposeConfig("CAT2",0,2000,0)
drvModbusAsynConfigure("0X1R","CAT2",1,5,1,10,0,100,"CAT2")
record(bo, "$(DEVNAME):HOMING_TRIGGER")
field(DTYP, "asynUInt32Digital")
field(OUT, "@asynMask(0X1R 1 0x1)")
field(ZNAM,"0")
field(ONAM,"1")
field(SCAN, "I/O Intr")
When I enter dbpr, it displays as follows:
epics> dbpr FMC01:HOMING_TRIGGER
ASG :               DESC:               DISA: 0             DISP: 0
DISV: 1             NAME: FMC01:SEARCH_0_TRIGGER            RBV : 0
RVAL: 0             SEVR: INVALID       STAT: UDF           TPRO: 0
VAL : 0
 Did I make a mistake somewhere?
Thanks
White
About errors in controlling the motor controller. White via Tech-talk
Prev: About errors in controlling the motor controller. White via Tech-talk
Next: Newbie question about SNL Dariush Hampai via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
