1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Subject: Re: What is the valueAlarm.active field?
From: Michael Davidsaver via Tech-talk <[email protected]>
To: David Bracey <[email protected]>
Date: Tue, 2 Dec 2025 18:51:30 -0800
On 12/2/25 3:06 PM, David Bracey via Tech-talk wrote:
What is the “valueAlarm.active” field?
A leftover in a specification document which was written without a clear statement of how it would be used.  So it has not been.
  Is it backed by any database field?
No.
fyi. you can tell this by passing 'pvget -vv' and noticing that 'active' is not shown, meaning that the server never pushes a value for this field.  When a server does not push an initial value for a field, it will probably never push any value.
 -m -vv:            Monitor in Raw mode.  Highlight fields marked as changed, show all valid fields.
dbracey@somebox:~$ pvget -v dbracey:xxxExample
dbracey:xxxExample epics:nt/NTScalar:1.0
  double value 0
  alarm_t alarm MAJOR DEVICE LOLO
    int severity 2
    int status 1
    string message LOLO
  structure timeStamp
    long secondsPastEpoch 1764694785
<SNIP>
    double minStep 0
  valueAlarm_t valueAlarm
    boolean active false
    double lowAlarmLimit 2
    double lowWarningLimit 4
What is the valueAlarm.active field? David Bracey via Tech-talk
Prev: What is the valueAlarm.active field? David Bracey via Tech-talk
Next: RE: mtca-evr-300rf,mrfioc2:failed to find/create object SDH via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <20252026
Next: Error that seems to suspend all .st programs McClanahan, Ryan via Tech-talk
