1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Subject: Weird question (related to possible EPICS abuse)
From: Graeme Winter via Tech-talk <[email protected]>
Date: Fri, 5 Dec 2025 15:44:21 +0000
Good morning
Working with an arinax MD3 here, the built-in EPICS interface seems to make the control software unreliable (if I enable it, the Java GUI just vanishes from time to time, not enabling it seems more reliable)
The epics interface allows things like
caput MD3:startRasterScanEx 0 1 1 0 0 0 0 0 100 100 1 1 1 1
Which follows
int startRasterScanEx(double, double, double, double, double, double, double, double, int, int, double, boolean, boolean, boolean)
I would like to use this interface, but by writing a proxy in EPICS (currently using the Python softIOC code) which I will “wrap” the more reliable exporter interface in
However
The nearest I could find to this is a waveform with 14 elements which is clearly not what the above interface is using as I would need to caput -a in that case, yet this worked
So
- is this some weird abuse of EPICS by the MD3 makers?
- is there a way to duplicate this with a python softIOC?
I am endeavoring to have a consistent network interface hence my interest in an EPICS proxy rather than mixing and matching though of course I could also just do that…
As always appreciate the support from the community
All the best Graeme
Prev: Re: Further OMS PC78 questions Peterson, Kevin M. via Tech-talk
Next: Re: Further OMS PC78 questions James P. Withrow via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  <2025>  2026
Prev: Re: Error that seems to suspend all .st programs Michael Davidsaver via Tech-talk
Next: Support for Pfeiffer HiPace with TC400 control unit Heinz Junkes (FHI) via Tech-talk
